Dzvents
Posted: Tuesday 28 June 2022 15:32
by aukesp
Hi All,
I am quiet a new bee and I am struggling with some Dzvents code.
problem is a have device
I have the following code:
		timer = { 'every 1 minutes at daytime' },
				local CurPower = domoticz.devices('ScreenBijkeuken')
				local oldvalue = domoticz.devices('SMACurPower')
				domoticz.log('Sensor value: ' .. oldvalue, domoticz.LOG_DEBUG)
--				CurPower.updateCustomSensor(oldvalue) -- this is step 2 update an virtual device
				domoticz.log('Device ' .. oldvalue.value .. ' was changed', domoticz.LOG_INFO)
I hoped to see the oldvalue in the logfile but i just got an error
2022-06-28 15:15:00.500 Error: dzVents: Error: (3.1.8) ...86)\Domoticz\scripts\dzVents\scripts/VirtualSwitches.lua:12: attempt to concatenate a table value (local 'oldvalue'
What I am doing wrong?
Re: Dzvents
Posted: Tuesday 28 June 2022 23:33
You forgot the read the value extension to old value. It is now referring to the device itself but you would like to have a value of that device. For example actualWatt value of SMACurPower:
local oldvalue = domoticz.devices('SMACurPower').actualWatt
Change .actualWatt to the device value you would like to use.
Re: Dzvents
Posted: Wednesday 29 June 2022 15:42
by aukesp
Thanks for your reply,
I try to find the device value, but how do I now what valua to use?
Where can I find this value name?
I only see state value's like state and value but they have also value nil.
Re: Dzvents
Posted: Wednesday 29 June 2022 15:44
It is all documented in the wiki: https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Especially in the devices section, there are attributes and methods for all but also device specific:
https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
Re: Dzvents
Posted: Wednesday 29 June 2022 16:00
by aukesp
Thanks, but still confusing.
For my temparature device i use temperature value because i found so on the forum.
At Wiki I do not find such device value names??
Could you please give me some extra info?
Re: Dzvents
Posted: Wednesday 29 June 2022 18:24
From the wiki:
Temperature sensor
.temperature: Number
.updateTemperature(temperature): Function. Note: temperature must be in Celsius. Use domoticz.toCelsius() to convert a Fahrenheit temperature to Celsius. Supports command options.
So to read the temperature use
local ReadTemp = domoticz.devices('YourTempDevice').temperature
To update a dummy temperature device to 30 degrees(that is not set by another hardware gateway!)
domoticz.devices('YourTempDevice').updateTemperature(30)
Re: Dzvents
Posted: Wednesday 13 July 2022 12:27
by aukesp
Hi Waltervl,
Thanks for your reply, this helps
