lastUpdate not the last!
Posted: Sunday 26 June 2022 20:00
by hestia
I've discovered there https://github.com/domoticz/domoticz/issues/4466
that
When the script is triggered by the device update you already know when it is updated (it is updated now)
The lastupdate value is updated after the script is triggered.
but my comment is true for scripts triggered by the device update. If you use a time based script or a script triggered by a different device and probe for the lastUpdate time it should report the real lastUpdate time
This is how it should work by design
But I think it doesn't work like this...
2 scripts to test it
-- the trigger script
LOGGING = domoticz.LOG_DEBUG
LOG_LEVEL = domoticz.LOG_DEBUG
local dev0 = 214
local dev1 = 271
local dev2 = 460
    logging =   {   level   =   LOGGING,
		devices = {dev0}
	execute = function(dz, triggerObject)
	_G.logMarker =  dz.moduleLabel
    dz.devices(dev1).toggleSwitch()
    dz.devices(dev2).toggleSwitch()
-- the triggered script
local dev1 = 271
local dev2 = 460
		devices = {dev1}
    dz.log(dz.devices(dev1).id .. ' ' .. dz.devices(dev1).lastUpdate.raw)
    dz.log(dz.devices(dev2).id .. ' ' .. dz.devices(dev2).lastUpdate.raw)
the log
2022-06-26 19:40:35.198 Status: dzVents: Info: ------ Start internal script: z_trigger: Device: "test 214 (Dummy)", Index: 214
2022-06-26 19:40:35.204 Status: dzVents: Debug: z_trigger: Processing device-adapter for test 271: Switch device adapter
2022-06-26 19:40:35.204 Status: dzVents: Debug: z_trigger: Constructed timed-command: On
2022-06-26 19:40:35.206 Status: dzVents: Debug: z_trigger: Processing device-adapter for test 460: Switch device adapter
2022-06-26 19:40:35.207 Status: dzVents: Debug: z_trigger: Constructed timed-command: On
2022-06-26 19:40:35.207 Status: dzVents: Info: z_trigger: ------ Finished z_trigger
2022-06-26 19:40:35.648 Status: dzVents: Info: ------ Start internal script: z_triggered: Device: "test 271 (Dummy)", Index: 271
2022-06-26 19:40:35.648 Status: dzVents: Info: z_triggered: 271 2022-03-28 21:26:25
2022-06-26 19:40:35.650 Status: dzVents: Debug: z_triggered: Processing device-adapter for test 460: Switch device adapter
2022-06-26 19:40:35.650 Status: dzVents: Info: z_triggered: 460 2022-03-17 21:40:16
2022-06-26 19:40:35.650 Status: dzVents: Info: z_triggered: ------ Finished z_triggered
2022-06-26 19:41:59.487 Status: dzVents: Info: ------ Start internal script: z_trigger: Device: "test 214 (Dummy)", Index: 214
2022-06-26 19:41:59.489 Status: dzVents: Debug: z_trigger: Processing device-adapter for test 271: Switch device adapter
2022-06-26 19:41:59.489 Status: dzVents: Debug: z_trigger: Constructed timed-command: Off
2022-06-26 19:41:59.491 Status: dzVents: Debug: z_trigger: Processing device-adapter for test 460: Switch device adapter
2022-06-26 19:41:59.491 Status: dzVents: Debug: z_trigger: Constructed timed-command: Off
2022-06-26 19:41:59.492 Status: dzVents: Info: z_trigger: ------ Finished z_trigger
2022-06-26 19:41:59.738 Status: dzVents: Info: ------ Start internal script: z_triggered: Device: "test 271 (Dummy)", Index: 271
2022-06-26 19:41:59.738 Status: dzVents: Info: z_triggered: 271 2022-06-26 19:40:35
2022-06-26 19:41:59.740 Status: dzVents: Debug: z_triggered: Processing device-adapter for test 460: Switch device adapter
2022-06-26 19:41:59.740 Status: dzVents: Info: z_triggered: 460 2022-06-26 19:40:35
2022-06-26 19:41:59.740 Status: dzVents: Info: z_triggered: ------ Finished z_triggered
The script is triggered by dev1 = 271, so it's lastUpdate is the previous one => OK
But it's the same for the other device dev2 = 460
even though it was updated after
and that it was not the trigger!
You would say that, we could know that it was updated with the one triggered, but we could have different conditions for the update and so the result is that we don't know if it was updated or not :-(
