Error from LUA script
MikeyMan
Post by MikeyMan »
I have a script running that calculates the average outside temperature. This has been running for a long time without any issues now.
However, recently i'm starting to get errors:
2022-06-25 00:45:00.740 Error: EventSystem: in Gemiddelde temperatuur: [string "local function DeviceUpdate(idx, value1) ..."]:32: attempt to index a nil value (local 'jsonData')
Haven't change the script, which looks as follows:
    local cmd = string.format("%d|0|%.2f", idx, value1)
  --print(cmd)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
Debug = "YES" -- Debugging aanzetten ("YES") of uitzetten ("NO")
local m = os.date('%M')
if (m % 5 == 0) then -- script loopt iedere 5 minuten
-- Variabelen instellen
--local temperature_name  = 'Gemiddelde Buitentemp'
local temperature_idx  = 64 --otherdevices_idx[temperature_name]
--local uitlees_name  = 'Ground Temperature (10 cm)'
local uitlees_idx  = 50 --otherdevices_idx[uitlees_name]
--Temperaturen van afgelopen 24 uur opvragen
local sQuery      = 'curl "http://10.0.0.30:8080/json.htm?type=graph&sensor=temp&idx='..tostring(uitlees_idx)..'&range=day"'
local handle=assert(io.popen(sQuery))
local raw = handle:read('*all')
handle:close()
--Ontvangen waarden verwerken
json = assert(loadfile '/home/pi/domoticz/scripts/lua/JSON.lua')()
local jsonData = json:decode(raw)
if Debug=='YES' then
  print (jsonData.title)
  print (jsonData.status)
  print (jsonData.result[1].d)
  print (jsonData.result[1].te)
--Gemiddelde temperatuur van afgelopen 24 uur bepalen
local sum = 0
local ave = 0
local elements = #jsonData.result
for i = 1, elements do
    sum = sum + jsonData.result[i].te
ave = sum / elements
  print('Gemiddeld: '..tostring(ave))
--Gemiddelde temperatuur opslaan in virtuele temperatuur sensor
DeviceUpdate(temperature_idx,ave)
Anyone got any idea what is going wrong here?
psubiaco
Re: Error from LUA script
Post by psubiaco »
What about replacing the line
with
commandArray[temperature_name]=tostring(ave)
It's much simpler than calling DeviceUpdate()
Also, it's better you check the result of query to get the list of temperature values, and check that format is ok, values are float, ...
Paolo
MikeyMan
Post by MikeyMan »
psubiaco wrote: Sunday 26 June 2022 11:43 What about replacing the line
with
I believe you immediately! I'll try your suggestion and see what happens.
My coding skills are virtually non existent :)
Is the query logged somewhere?
psubiaco
Post by psubiaco »
MikeyMan wrote: Sunday 26 June 2022 12:04 Is the query logged somewhere?
Everything is logged by Domoticz, in database, syslog or in the file specified in Domoticz run script /etc/init.d/domoticz
Use the print() function to log anything else than errors.
Paolo
MikeyMan
Post by MikeyMan »
Haha, domoticz.log in /var/log is 2 gb's. Lets see whats in there.
Edit; that's the same info as in the GUI.
However, did pinpoint that it wasn't working as correctly as i thought. Values did show up, however:
2021-11-15 00:00:11.472  Error: EventSystem: Warning!, lua script Gemiddelde temperatuur has been running for more than 10 seconds
Thats a long time ago already.
First occurence of the current error was last year:
2021-12-15 17:20:00.512  Error: EventSystem: in Gemiddelde temperatuur: [string "local function DeviceUpdate(idx, value1)
And some variations of the error:
2021-12-18 01:00:10.502  Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
Strangely the error has been gone for a while and then came back... Very strange.
Trying to run the curl i get the following:
pi@raspberrypi:~ $ curl "http://10.0.0.30:8080/json.htm?type=graph&sensor=temp&idx=50&range=day"
-bash: curl: command not found
MikeyMan
Post by MikeyMan »
What the...
After installing curl it was fixed it seems. How did that get removed?
Slightly different error now:
2022-06-27 10:00:00.497 Error: EventSystem: in Gemiddelde temperatuur: [string "local function DeviceUpdate(idx, value1) ..."]:55: table index is nil
2022-06-27 10:05:00.572 Status: LUA: Gemiddeld: 17.603718393654
2022-06-27 10:05:00.572 Error: EventSystem: in Gemiddelde temperatuur: [string "local function DeviceUpdate(idx, value1) ..."]:55: table index is nil
2022-06-27 10:10:01.305 Status: LUA: Gemiddeld: 17.606246901339
2022-06-27 10:10:01.306 Error: EventSystem: in Gemiddelde temperatuur: [string "local function DeviceUpdate(idx, value1) ..."]:55: table index is nil
Reverted to the earlier script, and now the error is gone.
psubiaco
Post by psubiaco »
I already suggested you to forget buggy DeviceUpdate function and just use
commandArray[DEVICENAME]=tostring(VALUE)
to pass the result to domoticz.
Paolo
MikeyMan
Post by MikeyMan »
psubiaco wrote: Monday 27 June 2022 10:54 I already suggested you to forget buggy DeviceUpdate function and just use
Thats what i tried. That resulted in the following error:
Changing back to the earlier code did fix that.
MikeyMan
Post by MikeyMan »
Now trying to swap temperature_name for temperature_idx.
psubiaco
Post by psubiaco »
As you see, the error is in the DeviceUpdate function, so you have to erase that function as it's not used anymore.
Paolo
MikeyMan
Post by MikeyMan »
psubiaco wrote: Monday 27 June 2022 11:01 As you see, the error is in the DeviceUpdate function, so you have to erase that function as it's not used anymore.
To recap, after installing curl, this was working without errors:
This was not working:
with this error:
After uncommenting this line:
I get no errors any more.
psubiaco
Post by psubiaco »
Ok, if you prefer you can also use
commandArray['Gemiddelde Buitentemp']=tostring(ave)
so, in this case, you don't need to define the variable temperature_name='Gemiddelde Buitentemp' as you did.
Paolo
MikeyMan
Post by MikeyMan »
psubiaco wrote: Monday 27 June 2022 11:25 Ok, if you prefer you can also use
Somehow it does run then, but doesnt update the value.
Script is now:
  --print(cmd)
handle:close()
local sum = 0
local ave = 0
--DeviceUpdate(temperature_idx,ave)
psubiaco
Post by psubiaco »
my mistake: commandArray in the simplest format can be used only with integer values.
In your case, you can use commandArray[1]={['UpdateDevice']=idx|0|value}:
	-- commandArray['Gemiddelde Buitentemp']=tostring(ave) -- works only if ave is integer!
    	commandArray[1]={['UpdateDevice']=temperature_idx..'|0|'..ave}
Paolo
MikeyMan
Post by MikeyMan »
psubiaco wrote: Tuesday 28 June 2022 12:30 Hi,
Thanks. I'll give that a try.
Strange it isn't throwing an error though?
