show blocks by parameter
kispalsz
Post by kispalsz »
I want a screen. Place columns and blocks on the screen. I want to specify the blocks to be. However, I only want them to appear under certain conditions. For example, I list all the lights in the house. But only those that are turned on would appear. If I click on 1, it will turn off and disappear from the list. I want it to disappear completely, the other burning lights to roll into its empty space.
Is this possible somehow?
kispalsz
Re: show blocks by parameter
Post by kispalsz »
Can anyone help with the above?
Lokonli
Post by Lokonli »
kispalsz wrote: Thursday 16 June 2022 19:37 Hi
You have to add some code to custom.js. Below an example for two switches.
Example of CONFIG.js:
var blocks = {}
blocks['light1'] = {
    idx: 79,
blocks['light2'] = {
    idx: 80,
var columns = {}
columns[1] = {
    blocks:  ['light1','light2'],
    width: 6
var screens = {}
screens[1] = {
    columns:  [1]
In custom.js add the following:
function hideBlockWhenOff(block) {
  if(block.device.Status!=="On") {
    block.addClass="hidden";
    else block.addClass="";
function getStatus_light1(block) {
  hideBlockWhenOff(block);
function getStatus_light2(block) {
