This module can only be loaded into one interpreter per process
Posted: Monday 13 June 2022 22:29
I'm in a process of creating a plugin for Unifi Protect. There is a python library called pyunifiprotect (https://github.com/briis/pyunifiprotect) and is used by Home Assistant. When I create a simple plugin it always fails on the importing part.
It always fails on: from pyunifiprotect import ProtectApiClient
Error in Domoticz Log:
Does anyone have an idea how to solve this?
# Unifi-Protect plugin
# Author: Wizzard72
# Versions:
# 0.0.1: First ...
<plugin key="UnifiProtect" name="Unifi Protect" author="Wizzard72" version="0.0.1" wikilink="">
<description>
<h2>Unifi Protect plugin</h2><br/>
</description>
<params>
<param field="Address" label="IP Address / DNS name of the Unifi Controller" width="200px" required="true" default="127.0.0.1"/>
<param field="Port" label="Port" width="30px" required="true" default="8443"/>
<param field="Username" label="Username" width="200px" required="true" default="[email protected]"/>
<param field="Password" label="Password" width="600px" required="true" default="password" password="true"/>
<param field="Mode1" label="Site Name" width="200px" required="true" default="default"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="None" value="0" default="true" />
<option label="Python Only" value="2"/>
<option label="Basic Debugging" value="62"/>
<option label="Basic+Messages" value="126"/>
<option label="Connections Only" value="16"/>
<option label="Connections+Queue" value="144"/>
<option label="All" value="-1"/>
</options>
</param>
</params>
</plugin>
import os
import sys
module_paths = [x[0] for x in os.walk( os.path.join(os.path.dirname(__file__), '.', '.env/lib/') ) if x[0].endswith('site-packages') ]
for mp in module_paths:
sys.path.append(mp)
import Domoticz
# For documentation: sudo pip3 install asyncio
# For documentation: sudo pip3 install pyunifiprotect
import queue
import threading
import time
import sys
import asyncio
class BasePlugin:
_versionCheck = None
_ProtectConn = None
def __init__(self):
return
def onStart(self):
strName = "onStart: "
Domoticz.Debug(strName+"called")
if (Parameters["Mode6"] != "0"):
Domoticz.Debugging(int(Parameters["Mode6"]))
else:
Domoticz.Debugging(0)
# check if version of domoticz is 2020.2 or higher
try:
if int(Parameters["DomoticzVersion"].split('.')[0]) < 2020: # check domoticz major version
Domoticz.Error(
"Domoticz version required by this plugin is 2020.2 (you are running version {}).".format(
Parameters["DomoticzVersion"]))
Domoticz.Error("Plugin is therefore disabled")
self.setVersionCheck(False, "onStart")
else:
self.setVersionCheck(True, "onStart")
except Exception as err:
Domoticz.Error("Domoticz version check returned an error: {}. Plugin is therefore disabled".format(err))
if not self._versionCheck:
return
self.login()
Domoticz.Heartbeat(5)
def onStop(self):
strName = "onStop: "
Domoticz.Debug(strName+"Pluggin is stopping.")
def onConnect(self, Connection, Status, Description):
strName = "onConnect: "
Domoticz.Debug(strName+"Connection = "+str(Connection))
Domoticz.Debug(strName+"Status = "+str(Status))
Domoticz.Debug(strName+"Description = "+str(Description))
def onMessage(self, Connection, Data):
strName = "onMessage: "
DumpHTTPResponseToLog(Data)
Domoticz.Debug(strName+"Data = " +str(Data))
strData = Data["Data"].decode("utf-8", "ignore")
status = int(Data["Status"])
def onCommand(self, Unit, Command, Level, Hue):
strName = "onCommand: "
Domoticz.Log(strName+"called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
strName = "onNotification: "
Domoticz.Log(strName+"Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
strName = "onDisconnect: "
def onHeartbeat(self):
strName = "onHeartbeat: "
def setVersionCheck(self, value, note):
strName = "setVersionCheck - "
if value is True:
if self._versionCheck is not False:
self._versionCheck = True
Domoticz.Log(strName+"Plugin allowed to start (triggered by: "+note+")")
elif value is False:
self._versionCheck = False
Domoticz.Error(strName+"Plugin NOT allowed to start (triggered by: "+note+")")
def login(self):
strName = "login: "
_protectConn = ProtectApiClient(Parameters["Address"], Parameters["Port"], Parameters["Username"], Parameters["Password"], verify_ssl=True)
await protectConn.update()
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
2022-06-13 22:27:16.048 Status: Protect: Started.
2022-06-13 22:27:16.048 Status: Protect: Entering work loop.
2022-06-13 22:27:16.572 Error: Protect: (UnifiProtect) failed to load 'plugin.py', Python Path used was '/home/paul/domoticz/plugins/Domoticz-Unifi-Protect/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2022-06-13 22:27:16.576 Error: Protect: Traceback (most recent call last):
2022-06-13 22:27:16.576 Error: Protect: File "/home/paul/domoticz/plugins/Domoticz-Unifi-Protect/plugin.py", line 47, in <module>
2022-06-13 22:27:16.576 Error: Protect: from pyunifiprotect import ProtectApiClient
2022-06-13 22:27:16.576 Error: Protect: File "/usr/local/lib/python3.9/dist-packages/pyunifiprotect/__init__.py", line 2, in <module>
2022-06-13 22:27:16.576 Error: Protect: from pyunifiprotect.api import ProtectApiClient
2022-06-13 22:27:16.576 Error: Protect: File "/usr/local/lib/python3.9/dist-packages/pyunifiprotect/api.py", line 21, in <module>
2022-06-13 22:27:16.576 Error: Protect: from pyunifiprotect.data import (
2022-06-13 22:27:16.576 Error: Protect: File "/usr/local/lib/python3.9/dist-packages/pyunifiprotect/data/__init__.py", line 1, in <module>
2022-06-13 22:27:16.576 Error: Protect: from pyunifiprotect.data.base import (
2022-06-13 22:27:16.576 Error: Protect: File "/usr/local/lib/python3.9/dist-packages/pyunifiprotect/data/base.py", line 21, in <module>
2022-06-13 22:27:16.576 Error: Protect: from pydantic import BaseModel
2022-06-13 22:27:16.576 Error: Protect: ImportError: Interpreter change detected - this module can only be loaded into one interpreter per process.
