Domoticz, MQTT and Sonoff basic with Tasmota: help Topic is solved
MichelFrance
Domoticz version: 2023.1
Post by MichelFrance »
I am running: Domoticz Version: 2022.1 on an ubuntu server and Sonoff Basic R1 and R2 with Tasmota 11.1.0.
The server also runs a MQTT server (mosquitto) and Zigbee2MQTT.
In Domoticz I created a new hardware "MQTT Auto Discovery Client Gateway with LAN interface" with Auto Discovery Prefix = homeassistant and the Zigbee devices are well recognized and are working.
But the Sonoff devices are not recognized.
Nothing in Domoticz log, but spying MQTT, I discovered that the Tasmota-Sonoff starts with this message:
tasmota/discovery/B4E62D24ED35/config {"ip":"192.168.1	...
So, I created a new hardware "MQTT Auto Discovery Client Gateway with LAN interface" with Auto Discovery Prefix = tasmota
Still no Sonoff detected in Domoticz, but now some messages in the log:
2022-06-09 15:02:08.104 Status: MQTT Broker tasmota: discovered: 323bb295-78c5-43da-841d-6abab3f6f234/323bb295-78c5-43da-841d-6abab3f6f234 (unique_id: 323bb295-78c5-43da-841d-6abab3f6f234)
2022-06-09 15:02:08.204 Error: MQTT Broker tasmota: MQTT_Discovery: Something other then 'config' received on discovery topic! (discovery/B4E62D24ED35/sensors/{"sn":{"Time":"2022-06-09T14:02:08"},"ver":1})!
2022-06-09 15:02:08.204 Error: MQTT Broker tasmota: MQTT_Discovery: Invalid/Unhandled data received! (Topic: discovery/B4E62D24ED35/sensors, Message: {"sn":{"Time":"2022-06-09T14:02:08"},"ver":1})
and the corresponding MQTT spying:
tele/tasmota_24ED35/LWT Online
cmnd/tasmota_24ED35/POWER (null)
tele/tasmota_24ED35/INFO1 {"Info1":{"Module":"GenericMB","Version":"11.1.0(tasmota)","FallbackTopic":"cmnd/DVES_24ED35_fb/","GroupTopic":"cmnd/tasmotas/"}}
tele/tasmota_24ED35/INFO2 {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-24ED35-3381","IPAddress":"192.168.1.105"}}
tele/tasmota_24ED35/INFO3 {"Info3":{"RestartReason":"Power On","BootCount":18}}
stat/tasmota_24ED35/RESULT {"POWER":"ON"}
stat/tasmota_24ED35/POWER ON
domoticz/in {"idx":489,"nvalue":1,"svalue":"","Battery":100,"RSSI":10}
tele/tasmota_24ED35/STATE {"Time":"2022-06-09T14:02:03","Uptime":"0T00:00:10","UptimeSec":10,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Lejardindesfleurs","BSSId":"28:D1:27:81:00:E2","Channel":6,"Mode":"11n","RSSI":100,"Signal":-19,"LinkCount":1,"Downtime":"0T00:00:04"}}
tasmota/discovery/B4E62D24ED35/config {"ip":"192.168.1.105","dn":"Tasmota","fn":["Tasmota",null,null,null,null,null,null,null],"hn":"tasmota-24ED35-3381","mac":"B4E62D24ED35","md":"GenericMB","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"11.1.0","t":"tasmota_24ED35","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"sho":[0,0,0,0],"ver":1}
tasmota/discovery/B4E62D24ED35/sensors {"sn":{"Time":"2022-06-09T14:02:08"},"ver":1}
domoticz/in {"idx":489,"nvalue":0,"svalue":"","Battery":100,"RSSI":10}
stat/tasmota_24ED35/RESULT {"POWER":"OFF"}
stat/tasmota_24ED35/POWER OFF
tele/tasmota_24ED35/STATE {"Time":"2022-06-09T14:07:03","Uptime":"0T00:05:10","UptimeSec":310,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Lejardindesfleurs","BSSId":"28:D1:27:81:00:E2","Channel":6,"Mode":"11n","RSSI":100,"Signal":-28,"LinkCount":1,"Downtime":"0T00:00:04"}}
What is going bad? Someone to help me? Link to a good tutorial to interface Sonoff basic/tasmota to Domoticz?
Any suggestion?
Thanks in advance
M.
MichelFrance
Re: Domoticz, MQTT and Sonoff basic with Tasmota: help
Answer to myself:
it works with "MQTT Client Gateway with LAN interface" and a dummy switch with od configured in Tasmota.
I'd like to have it work with auto discovery if possible, so this topic is not full closed. Any idea?
Did you use Tasmota
SetOption19 1
To set tasmota device to MQTT Autodiscover protocol?
MichelFrance
Thank you!
MichelFrance wrote: Friday 10 June 2022 7:37 Thank you!
You are welcome ;-) I suppose you got it working now?
MichelFrance
Yes!
