Activate google devices from domoticz
Alexa, Google Home and Siri
arjan93
Post by arjan93 »
Hii all,
Yesterday I`ve bought a bluebot vacuum cleaner. This cleaner is supported bij Google but not by domoticz.
Is het possible to activate the cleaner with a virtual switch in domoticz? I have controlicz installed but what
I understand is that this only works from google to domoticz and not from domoticz to google.
Does anyone have an idea if this is possible?
mgugu
Re: Activate google devices from domoticz
Post by mgugu »
Check Google Assistant relay https://assistantrelay.com/
This exposes the Google Assistant Service as a REST API.
I use that to issue google voices from text via REST API. You can also launch routines
This run on nodejs. Running for many years without any problem
arjan93
Post by arjan93 »
Thanks, I will take a look at it :)
