Persistent data
Posted: Monday 06 June 2022 20:02
by Toulon7559
A database or a file is an appropriate medium to store information, manipulating it for reading and writing,
and it 'survives' when a function or computer stops.
As element in Domoticz the user variables are a means to keep values, with the nice aspect of individual adressing.
Also, after initiation they automatically become part of Domoticz' background database.
Is in Python 2.x and Python 3.x an equivalent available for those Domoticz' user variables?
Or required to mimick (howto?)?
Re: Persistent data
Posted: Tuesday 07 June 2022 0:14
by Number8
Are you looking for something like data pickle?
Re: Persistent data
Posted: Tuesday 07 June 2022 8:24
by Toulon7559
Never heard of
pickling, but
the description looks promising, because really simple structure and very short scriptlines.
Have also been thinking of similar application of a Python dictionary as auxiliary file, but then script quickly expands.
Re: Persistent data
Posted: Tuesday 07 June 2022 9:01
by Number8
yes I use it in a python script, pretty easy to set-up
Re: Persistent data
Posted: Thursday 09 June 2022 10:19
by Toulon7559
Meanwhile (with help from Google, and side-looking to pickle) also found a setup making use of
- a default & working dictionary,
- at end of script-cycle saving the dictionary for backup as json-file, and
- at start of next script-cycle after read-back reconstruction as reference dictionary.
The script-segment in the spoiler below demonstrates an application of such setup for read-out for a weatherstation, and generation of some derived values.
BE AWARE THAT THIS IS NOT A RUNNING SCRIPT BY ITSELF, BUT A SEGMENT FOR DEMONSTRATION OF THE SETUP,
extracted from
this Python3.x application!!!
- Spoiler: show
- #!/usr/bin/python3
# THIS IS A SEGMENT OF A PYTHON SCRIPT JUST DEMONSTRATING MANIPULATION OF A DICTIONARY AS EXTERNAL, WORKING 'MEMORY'
# IT CANNOT BE RUN STAND-ALONE, BUT NEEDS HEAD & TAIL TO BECOME USEFUL!!!!!!!
# [Other functions of script, inculding preset & definition for variables]
# Line xxx = Rain_Cumulation & Extreme values & Times
print (' Functions for processing of Rain-values & Extremes ToBeDefined/Added')
# Define default list for cumulations and extremes
# Line xxx = Setup of framework for dictionary
# Initial contents in the dictionary to be tuned with realistic values at date&time of start-up !!!!!!!
Aux_dict = {'ZDate': 7, 'ZTime': 1330, 'Rain_Today': 0.0, 'Rain_Yesterday': 0.7, 'Rain_ThisMonth': 5.5, 'Rain_ThisYear': 283.1, 'TempCMax_Val': 11.2, 'TempCMax_Time': 0, 'TempCMin_Val': 25.2, 'TempCMin_Time': 0, 'RHumMax_Val': 60, 'RHumMax_Time': 0, 'RHumMin_Val': 99, 'RHumMin_Time': 0, 'WGustMax_Val': 0, 'WGustMax_Time': 0, 'SolRadMax_Val': 0, 'SolRadMax_Time': 0, 'Test_Value': 45.00}
# Test the layout
print(Aux_dict)
# Reference for test on single value
print(Aux_dict['Test_Value'])
# Test change of single value
Aux_dict['Test_Value'] = 2
print(Aux_dict)
# Line xxx = Read the dedicated, earlier saved version of the dictionary
# reading the data from the file
with open('/home/pi/Veurne_dict.json') as f:
data = f.read()
print("Data type before reconstruction : ", type(data))
# reconstructing the data as a dictionary
js = json.loads(data)
print("Data type after reconstruction : ", type(js))
print(js)
# Replace working dictionary by read copy
Aux_dict = js
# Line xxx = Calculate Rain-values and adjust Extreme Values & Times of Occurrence
# Line xxx = Setup for calculation of Rain_Today, Rain_ThisMonth and Rain_ThisYear
# Rain_Today = Rain accumulated today by addition of each 10minute-value
# Rain_Yesterday = Rain accumulated this Month at end of Yesterday
# Rain_LastMonth = Rain accumulated this Year at end of Last Month
# Read from datafile the actual values for Date, Time & Rain_since_midnight
# Line xxx = Check NewYear change and reset values
print('NewYear transition to be added')
# RainRate = Rain/lastHour = 6 * Rain10min
# if (New_Day = (Date <> ZDate)) then
# Rain_Today = 0
# if (New_Month = (Date < ZDate)) and (Time < 0010) then
# Rain_LastMonth = Rain_ThisYear
# Rain_Today = 0, Rain_Yesterday = 0, Rain_ThisMonth = 0
# if Time > 0010 and Time < 2355 then
# Rain_Today = Rain_since_midnight
# Rain_ThisMonth = Rain_Yesterday + Rain_Today
# Rain_ThisYear = Rain_ThisYear + Rain_Today
# store values
# else
# Rain_Yesterday = Rain_ThisMonth
# store value
# Line xxx = Setup to determine new extreme value & time since midnight
# if Time < 0010 then
# Read values and store values×
# else
# if Value > Val_Max then
# Val_Max = Value, Time_Max = Time, store value&time
# if Value < Val_Min then
# Val_Min = Value, Time_Min = Time, store value&time
# Line xxx = Realization of calculation of Rain_Today
# in line with setup mentioned above, is reset of Rain_Today at change of date
# Line xxx = Check midnight change and reset Rain_Today
if Rain_incl == 1:
# Rainrate by extrapolation
RainRate1 = 6 * Rain10min
print('RainRate1 = ',RainRate1)
# Rainrate by cumulation of last 6 10minute-values
RainRate2 = round(float( obj_test[17][4] + obj_test[17][4] +obj_test[16][4] + obj_test[15][4] + obj_test[14][4] + obj_test[13][4]), 1)
print('RainRate2 = ',RainRate2)
if ( int(DD_CET) != int(Aux_dict['ZDate']) ):
Rain_Today = 0
Aux_dict['Rain_Today'] = 0
# Line xxx = Realization of calculation of Rain_ThisMonth
# Line xxx = Check start of Month and backup/reset values
if ( int(DD_CET) < int(Aux_dict['ZDate']) ):
RainLastMonth = float(Aux_dict['Rain_ThisYear'])
Aux_dict['Rain_LastMonth'] = RainLastMonth
Aux_dict['Rain_Yesterday'] = 0
Aux_dict['Rain_ThisMonth'] = 0
Aux_dict['ZDate'] = DD_CET
Aux_dict['ZTime'] = HHMM_CET
# Line xxx = Update/refresh the Rain-values
if ( int(HHMM_CET > 10) and int(HHMM_CET < 2355)) and (Rain_incl == 1):
RainIncrease = float(Rain10min)
RainToday = float(Aux_dict['Rain_Today']) + RainIncrease
Aux_dict['Rain_Today'] = RainToday
RainThisMonth = float(Aux_dict['Rain_Yesterday']) + RainIncrease
Aux_dict['Rain_ThisMonth'] = RainThisMonth
RainThisYear = float(Aux_dict['Rain_ThisYear']) + RainIncrease
Aux_dict['Rain_ThisYear'] = RainThisYear
else:
Aux_dict['Rain_Yesterday'] = Aux_dict['Rain_ThisMonth']
print('Date&Time + Rain values included')
# Line xxx = Realization of adjustment of Extremes
if ( int(HHMM_CET) < 10):
Aux_dict['TempCMax_Val'] = TempC_SI
Aux_dict['TempCMax_Time'] = str(dattim7)
Aux_dict['TempCMin_Val'] = TempC_SI
Aux_dict['TempCMin_Time'] = str(dattim7)
Aux_dict['RHumMax_Val'] = RHum_SI
Aux_dict['RHumMax_Time'] = str(dattim7)
Aux_dict['RHumMin_Val'] = RHum_SI
Aux_dict['RHumMin_Time'] = str(dattim7)
Aux_dict['WGustMax_Val'] = WindG_SI
Aux_dict['WGustMax_Time'] = str(dattim7)
Aux_dict['SolRadMax_Val'] = SolRad_SI
Aux_dict['SolRadMax_Time'] = str(dattim7)
Aux_dict['ZDate'] = str(DD_CET)
Aux_dict['ZTime'] = str(HHMM_CET)
if ( float(TempC_SI) > float(Aux_dict['TempCMax_Val']) ):
Aux_dict['TempCMax_Val'] = str(TempC_SI)
if ( float(TempC_SI) < float(Aux_dict['TempCMin_Val']) ):
Aux_dict['TempCMin_Val'] = float(TempC_SI)
if ( float(RHum_SI) > float(Aux_dict['RHumMax_Val']) ):
Aux_dict['RHumMax_Val'] = str(RHum_SI)
if ( float(RHum_SI) < float(Aux_dict['RHumMin_Val']) ):
Aux_dict['RHumMin_Val'] = float(RHum_SI)
if ( float(WindG_SI) > float(Aux_dict['WGustMax_Val']) ):
Aux_dict['WGustMax_Val'] = float(WindG_SI)
if ( float(SolRad) > float(Aux_dict['SolRadMax_Val']) ):
Aux_dict['SolRadMax_Val'] = str(SolRad_SI)
# Line xxx = Make backup copy with filename tuned to station_name
Veurne_dict = Aux_dict
print
print('Backup file')
print(Veurne_dict)
# Line xxx = Save station dictionary
# Make JSON-file
with open('/home/pi/Veurne_dict.json', 'w') as outfile:
json.dump(Veurne_dict, outfile)
print ('End of calculation of Rain-Values & Extreme Values')
# [More other functions of script]
Re: Persistent data
Posted: Friday 10 June 2022 9:12
by Number8
Good to know, thanks
Re: Persistent data
Posted: Tuesday 16 May 2023 19:11
by Toulon7559
Rummaging with Google for a completely different aspect, found
this contribution by Xorfor:
is a setup which more directly links Python to the facilities & services of Domoticz, including the uservariables and devices.
IMHO it even enables that a Python-script and lua/dzVents-script share common data from Domoticz, avoiding seperate specific constructions & translations.
Seems quite useful, but although already existing a few years, must admit that never seen an application.
Observation May24, 2025:
Apparently Xorfor has blocked access to the related section of Github
