STrange Behavior with this script
Posted: Sunday 05 June 2022 11:19
HI guys,
I need an help on this script, that is running since 2018 like a charme
is a script form my irrigation system and works like that:
the script is triggered from one device and one timer
when the dummy device irrig is switch on, two dummy (v_01 and v_02 are switched on for some minutes with .forMin(), and irrig is switched off with .afterMin() for the same amount of minutes.
When the device irrig is switched off, two dummy (v_01 and v_02 are switched off, all the queue are cancelled, some calculation about the water consumption using irrig.lastUpdate.secondsAgo() are done and update some counters.
I've inserted a log immediately after execute
Now I've noticed that the script run twice as is triggered for example ON, like log shows:
I'm blocked with the debug because I really don't understand what is happening, because I never had this problem.
I'm pretty sure about that, because the calculation of the water flow return the first time the right number of seconds, and immediately zero, because on the run of the script irrig.lastUpdate.secondsAgo() return zero (and this is correct)
I've ever had water calculation, but now is 0 at all, so I'm sure that the script before was running good.
What's happenig?
My setup
Thanx in advance
Fabrizio
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
local notificationdevice = {'iPhone6S','iPadAir','PC','Laptop'}
-- 'active' controls if this entire script is considered or not
active = true, -- set to false to disable this script
-- trigger
-- can be a combination:
devices = {'Irrigatore'},
timer = {'30 minutes after sunset'}
--timer = {'at 21:00'}
logging = {
level = domoticz.LOG_DEBUG,
marker = "Irrigazione: "
-- actual event code
-- in case of a timer event or security event, device == nil
execute = function(dz, device, tginfo)
dz.log("EVENTO "..tginfo.type)
local v_01 = dz.devices("Valvola_01")
local v_02 = dz.devices("Valvola_02")
local irrig = dz.devices("Irrigatore")
--local webcam= dz.devices("Webcam Sala")
local rain = dz.devices("Rain").rain
local baro= string.lower(dz.devices("THB").forecastString)
local waterConsumption=dz.devices("water")
local tExt=math.floor(dz.devices("Temperatura Esterna").temperature)
local notifyText =""
local freqTime = ''
local frequenza = dz.devices("Frequenza Irrigatore").level
local freqState = dz.devices("Frequenza Irrigatore").state
local hum1 = 40
local hum2 = 40
local tRif=dz.variables('maxTemp').value
if (frequenza == 0) then
freqTime = ''
elseif (frequenza == 10) then
freqTime = 'on mon, tue, wed,thu, fri, sat, sun'
elseif (frequenza == 20) then
freqTime = 'on mon, wed, fri, sun'
elseif (frequenza == 30) then
freqTime = 'on sun'
dz.log("Rain Ratio: "..rain)
dz.log("Meteo Status: "..baro)
--dz.log(">>>>>"..dz.BARO_CLOUDY)
dz.log("Temp tExt: "..tExt)
dz.log("Frequ: "..freqTime)
dz.log("HUM01: "..hum1)
dz.log("HUM02: "..hum2)
hum1 = dz.devices("Soil Moisture 1").moisture
hum2 = dz.devices("Soil Moisture 1").moisture
dz.log("NEW HUM01: "..hum1)
dz.log("NEW HUM02: "..hum2)
--newtempoIrrigazione01=(90-hum1)/(90-5)*60
--newtempoIrrigazione02=(90-hum2)/(90-5)*60
--select algoritm
if (dz.devices('Rain Evaluation').state == "Yes") then
waterIsOK = (rain < 0.5 or baro ~= "rain")
elseif (dz.devices('Rain Evaluation').state == "No") then
waterIsOK = true
--dz.log("alg ")
dz.log("Test water ok: "..tostring(waterIsOK))
if (waterIsOK) then
--if (rain < 0.5 or baro ~= "rain") then
if(tginfo.type==dz.EVENT_TYPE_DEVICE) then
newtempoIrrigazione01=dz.helpers.irrigationTime(hum1,tRif,baro)
newtempoIrrigazione02=dz.helpers.irrigationTime(hum2,tRif,baro)
totalTime=math.max(newtempoIrrigazione01,newtempoIrrigazione02)
dz.log("Total Time: "..totalTime)
notifyText=notifyText.." Irrigazione attivata per \n"
notifyText=notifyText.."Valvola 01 :"..tostring(newtempoIrrigazione01).." minuti \n"
notifyText=notifyText.."Valvola 02 :"..tostring(newtempoIrrigazione02).." minuti \n"
notifyText=notifyText.."Tempo Totale :"..tostring(totalTime).." minuti \n"
notifyText=notifyText.."Temperatura esterna "..tostring(tRif).."°C \n"
notifyText=notifyText.."Previsione "..baro
if (irrig.state=="On") then
--waterConsumption.updateCustomSensor(2)
dz.log("inzio irrigazione")
dz.helpers.notification(dz,'Irrigazione',notifyText,'water_drops',notificationdevice)
dz.devices("irrigazioneText").updateText(notifyText)
v_01.switchOn().forMin(newtempoIrrigazione01)
v_02.switchOn().forMin(newtempoIrrigazione02)
dz.log("EVENTO..ON")
irrig.switchOff().afterMin(totalTime)
dz.log("EVENTO..OFF afterMin")
dz.helpers.alexa(dz,"Inizio Irrigazione, durata "..totalTime.." minuti",10)
message= 'mosquitto_pub -t irrigtime -m "{\\"tempoirrigazione\\":'..totalTime..'}"'
dz.log(message)
dz.executeShellCommand(message)
if irrig.state=="Off" then
irrig.cancelQueuedCommands()
v_01.cancelQueuedCommands()
v_02.cancelQueuedCommands()
v_01.switchOff().repeatAfterMin(1,5)
v_02.switchOff().repeatAfterMin(1,5)
dz.devices("irrigazioneText").updateText("Stop")
--calcolo consumo acqua
local q1 = 0.7 --litri al minuto
local n_irrigatori=2 --numero n_irrigatori
local dt = math.floor(irrig.lastUpdate.secondsAgo) --tempo in secondi di emissione acqua
dz.log("Time "..dt)
waterConsumption.updateCustomSensor(math.floor(irrig.lastUpdate.secondsAgo/60*0.7*2))
waterConsumption.updateCustomSensor(0).afterMin(5)
--contatore incrementale
dz.devices('Water Counter').updateCounter(math.floor(irrig.lastUpdate.secondsAgo/60*0.7*2))
--scrivo il riassunto updateCustomSensor
local riassunto = os.date("%d/%m/%y %H:%M").."\nTempo effettivo: "..tostring(math.floor(irrig.lastUpdate.secondsAgo/60)).." minuti\n"
riassunto = riassunto.."Litri effettivi: "..tostring(math.floor(irrig.lastUpdate.secondsAgo/60*0.7*2)).."\n"
dz.devices("irrigazioneText").updateText(riassunto)
--notifiche
dz.log("2")
dz.helpers.notification(dz,'Irrigazione', "Stop\n\n"..riassunto,'water_drops',notificationdevice)
dz.helpers.alexa(dz,"Fine Irrigazione, durata totale"..tostring(math.floor(irrig.lastUpdate.secondsAgo/60)).." minuti",10)
stop=0
message= 'mosquitto_pub -t irrigtime -m "{\\"tempoirrigazione\\":'..stop..'}"'
if(tginfo.type==dz.EVENT_TYPE_TIMER) then
if(freqTime ~= "") then
if (dz.time.matchesRule(freqTime)) then
irrig.switchOn()
dz.log("EVENTO..ON Timer")
dz.log("Ogni tot giorni")
dz.helpers.notification(dz,'Irrigazione', "Disattivo. Impostato a: "..freqState,'water_drops',notificationdevice)
dz.log("Disattivo")
dz.helpers.notification(dz,'Irrigazione', "Impianto Disattivato",'water_drops',notificationdevice)
dz.log("Pioggia")
dz.helpers.notification(dz,'Irrigazione','Piove '..tostring(math.floor(rain))..' mm','water_drops', notificationdevice)
irrig.switchOff().silent()
dz.devices("irrigazioneText").updateText("Piove")
}when the dummy device irrig is switch on, two dummy (v_01 and v_02 are switched on for some minutes with .forMin(), and irrig is switched off with .afterMin() for the same amount of minutes.
2022-06-05 11:14:02.073 Status: dzVents: Info: Irrigazione: : EVENTO device
2022-06-05 11:14:02.317 Status: dzVents: Info: Irrigazione: : EVENTO deviceI'm blocked with the debug because I really don't understand what is happening, because I never had this problem.
What's happenig?
My setup
Version: 2022.1 (build 14352)
Build Hash: 5765540b9
Compile Date: 2022-06-03 07:39:12
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Uptime: 17 Hours, 30 Minutes, 25 Seconds
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs
Fabrizio
