Long shot with TFA Dostmann 30.3238.06
DJathome
Domoticz version: 2025.1
Post by DJathome »
Hi there all,
Since I could lay my hands on this TFA Dostmann 30.3238.06 pool temp sensor I was wondering if I could get its measurements in Domoticz. :idea:
I know I am cutting lots of corners here, but since the sensor seems to communicate with an indoor unit using 868 Mhz, so the idea to use a USB 868MHz transceiver on my 'Domoticz-running' Raspberry Pi seems not so far fetched. :geek:
Even more wishful thinking on my part was looking at the USB transceiver TFA Dostmann sells themselves.
This is the one: TFA Dostmann 30.3175 USB-transceiver Draadloos 868 MHz, I did not find a lot of info on this transceiver let alone a manual worthy of that name.
Any idea's in the community?
Thanks a lot in advance!
DJ
DJathome
Re: Long shot with TFA Dostmann 30.3238.06
Post by DJathome »
Version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 09:34:32
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Still a newbie here but it seems not a lot of people are in the same boat as me.
Nevertheless I was tinkering a bit in my config.
Since I have a P1 meter also in the setup (on another USB port on the Pi4) I ended up here;
I do understand the point here but amongst other things I fail to see how to make the suggested settings stick in de /dev directory.
Using sudo mknod /dev/ttyUSB-TFA868USB c 188 1, I do get the new TTY in the /dev list.
In Domoticz I then can also find it listed in the dropdown for serial port in Hardware.
True, maybe I have to select a modus in my new hardware device but even then
this does not get me further, because a cat on tty-USB-TFA868USB results in;
cat: ttyUSB-TFA868USB: No such device or address
Moreover, when I reboot the Pi all newly added references to new tty* disappear in /dev
As suggested in the quoted topic above I added a rule file under /etc/udev/rules.d named 99-usb-serial.rules with the following content;
Maybe some things still are missing in this file.
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="AQ5MU6U0", SYMLINK+="ttyUSB-SMARTM-P1”
SUBSYSTEM=="tty", ATTRS{idVendor}==“6666”, ATTRS{idProduct}==“5555”, ATTRS{serial}==“0123456”, SYMLINK+="ttyUSB-TFA868USB”
In my limited knowledge I might be cutting a lot of corners here but thanks for your attention by the way.
DJ
DJathome
Post by DJathome »
Version: 2022.1
Snooping around in my Pi I did find that when I plug the USB stick there comes a new item in /dev
It is simply called usb, if I then go to /dev/usb I see there hiddev0, if enter sudo cat hiddev0 I can see a repeating pattern;
*?Q???????(????????*?Q???????(????????*?Q???????(????????*
Unplugging the USB receiver stick results in an error;
cat: hiddev0: Input/output error ending the output.
So I guess the Pi is 'reading' some data from the USB port but lacking a protocol setting it is unable to interprete the read info.
I tried to set a modus for the hardware but Domoticz answers this "can only be set using RFXmngr for now".
I do not have a window machine to run RFXmngr and until now I fail to see how one can get around this.
Any idea's would be welcome
DJ
DJathome
Post by DJathome »
I know I am asking quite specific questions, but is there really no one that has something to share even if it were that I am in a dead end here?
Even that would be greatly appreciated.
DJ
FireWizard
Post by FireWizard »
Hi @DJathome.,
Perhaps this: https://github.com/merbanan/rtl_433/issues/1603 might help you.
DJathome
Post by DJathome »
Hi FireWizard,
Once again thanks for your support!!!!!!
I will look in to this further later on (at this moment the water in the pool is to warm to resist) :lol:
DJ
