Help with error message
Posted: Friday 27 May 2022 12:35
Decided to build new Domoticz server and move from Phoscon/deConz to zigbee2mqtt, followed instructions on z2m site, build and install went fine without errors however I could not access the z2m frontend, if I run "sudo npm start" it all works, I can see the front end, pair devices and see them in Domoticz but as soon as I "ctrl c" and stop the process and then try and start it permanently with "sudo systemctl start zigbee2mqtt" and then check if its running with "systemctl status zigbee2mqtt" I get this, I don't understand why it seems to imply it's been running since Sat 21st
pi@Domoticz-New:/opt/zigbee2mqtt $ systemctl status zigbee2mqtt
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2022-05-21 13:00:49 BST; 5 days ago
Main PID: 469 (npm)
Tasks: 23 (limit: 2059)
CGroup: /system.slice/zigbee2mqtt.service
├─469 npm
├─619 sh -c node index.js
└─620 node index.js
May 21 13:01:03 Domoticz-New npm[469]: at Array.forEach (<anonymous>)
May 21 13:01:03 Domoticz-New npm[469]: at rmkidsSync (/opt/zigbee2mqtt/node_modules/rimraf/rimraf.js:336:26)
May 21 13:01:03 Domoticz-New npm[469]: at rmdirSync (/opt/zigbee2mqtt/node_modules/rimraf/rimraf.js:329:7)
May 21 13:01:03 Domoticz-New npm[469]: at Function.rimrafSync [as sync] (/opt/zigbee2mqtt/node_modules/rimraf/rimraf.js:301:9)
May 21 13:01:03 Domoticz-New npm[469]: at /opt/zigbee2mqtt/lib/util/logger.ts:138:20
May 21 13:01:03 Domoticz-New npm[469]: at cleanup (/opt/zigbee2mqtt/lib/util/logger.ts:136:21)
May 21 13:01:03 Domoticz-New npm[469]: (Use `node --trace-warnings ...` to show where the warning was created)
May 21 13:01:03 Domoticz-New npm[469]: (node:620) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a prom
May 21 13:01:03 Domoticz-New npm[469]: (node:620) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-z
lines 1-20/20 (END)
TIA
Dave
Main PID: 469 (npm)
├─469 npm
└─620 node index.js
lines 1-20/20 (END)
TIA
Dave
