Extraction of meteo-data from CWOP-table
Posted: Wednesday 25 May 2022 11:32
by Toulon7559
CWOP is a rather 'legacy' meteo-service, just concentrating on the basic meteo-values:
however, it still acts as a worldwide 'feeder' for NWS and NOOA using APRS.
They also redistribute the received data: the 'raw data-table' below is an example (as shown for CWOP-station EW4337).
For some simple meteo-applications that contains sufficient information, so why spending a lot of effort for calling the 'more luxury' servers?
Getting such CWOP-table is simplicity itself, compared to more 'protected' setups like for WUnderground and WOW_UK:
you just need to know the stationcallsign of 2 letters plus 4 digits, and the 2 url-calls mentioned below will provide the data-file.
Example for raw APRS-data: https://www.findu.com/cgi-bin/raw.cgi?call=EW4337
Example for raw Weather-data: https://www.findu.com/cgi-bin/rawwx.cgi?call=EW4337
Extraction of data from the datafile also seems simple, because all values always at same position in the 'basic' dataline and with same format.
To be aware that date&time-value is condensed pack with Day+UTC/Zulu-time and, units of values are 'imperial/american', and therefore for applications with 'Local-time' and SI-units a conversion is needed after extraction.
This document in section 6b explains the setup of the datalines.
Who has a script-idea suitable to grab & dissect the actual data of a CWOP-station,
as available in the bottom data-line of the APRS/Weather-data (which holds the most recent data)?
;-) A PHP-script for grab & dissect on the APRS/Weather-data would be ideal,
because it could be put in webspace as a support plugin commmonly serving various users ....
Re: Extraction of meteo-data from CWOP-table
Posted: Sunday 29 May 2022 19:30
by Toulon7559
Direct url-call by browser without any problem yields the table in previous message.
As next step applied the below scriptlines as function to capture the contents of an url;
working in other lua-files without problems for urls related to json-files en xml-files.
function os.capture(cmd, raw)
    local f = assert(io.popen(cmd, 'r'))
    local s = assert(f:read('*a'))
    f:close()
    if raw then return s end
    s = string.gsub(s, '^%s+', '')
    s = string.gsub(s, '%s+$', '')
    s = string.gsub(s, '[\n\r]+', ' ')
    return s
Subsequent simple implementation of this function as part of lua-file for grab & print.
    result=os.capture('curl -s "https://www.findu.com/cgi-bin/rawwx.cgi?call='..CWOP_System_ID..'"')
    if (DEBUG == 1) then
        print('Table-File CWOP_Weather')
        print(result)
But such setup produces a print of an apparently empty file ...........
Digging a bit deeper (in the source-info of the browser-picture) detect that the output of the url-call looks like a HTML-file,
unexpectedly turning this exercise into webscraping-effort, instead of just reading&storing the datafile after an url-call.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"
"http://www.w3.org/TR/REC-html40/loose.dtd"><HTML>
<HEAD>
<meta http-equiv="expires" content="-1">
<meta http-equiv="pragma" content="no-cache">
<TITLE>Raw Weather for EW0725</TITLE>
</HEAD>
<BODY alink="#008000" bgcolor="#F5F5DC" link="#0000FF" vlink="#000080">
EW0725>APRS,TCPXX*,qAX,CWOP-6:@290650z5217.78N/00648.33E_345/001g004t051r000p001P001b10149h86L201.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@290700z5217.78N/00648.33E_099/000g001t051r000p001P001b10149h85L212.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@290710z5217.78N/00648.33E_276/001g004t051r000p001P001b10149h83L220.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@290720z5217.78N/00648.33E_073/000g003t052r000p001P001b10149h82L234.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@290730z5217.78N/00648.33E_107/000g003t052r000p001P001b10148h82L239.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@290740z5217.78N/00648.33E_085/000g003t053r000p001P001b10147h79L192.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@290750z5217.78N/00648.33E_167/000g003t052r000p001P001b10147h78L116.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@290800z5217.78N/00648.33E_080/000g003t052r000p001P001b10147h80L148.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@290810z5217.78N/00648.33E_094/000g003t052r000p001P001b10147h82L144.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@290820z5217.78N/00648.33E_260/000g003t052r000p001P001b10147h83L089.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@290830z5217.78N/00648.33E_223/000g003t051r002p003P003b10148h86L058.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@290840z5217.78N/00648.33E_063/000g001t051r002p003P003b10149h88L148.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@290850z5217.78N/00648.33E_056/001g006t050r002p003P003b10149h87L291.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@290900z5217.78N/00648.33E_073/000g001t051r002p003P003b10149h87L349.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@290910z5217.78N/00648.33E_022/000g002t052r002p003P003b10148h84L423.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@290920z5217.78N/00648.33E_170/000g003t053r002p003P003b10148h81L279.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@290930z5217.78N/00648.33E_023/000g004t053r000p003P003b10147h81L305.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@290940z5217.78N/00648.33E_043/001g003t054r000p003P003b10147h80L461.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@290950z5217.78N/00648.33E_278/001g005t054r000p003P003b10147h76L489.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291000z5217.78N/00648.33E_271/001g005t054r000p003P003b10147h73L336.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291010z5217.78N/00648.33E_252/002g005t054r000p003P003b10146h73L416.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291020z5217.78N/00648.33E_339/001g006t054r000p003P003b10146h74L172.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291030z5217.78N/00648.33E_131/003g003t...r000p003P003b.....h...weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@291040z5217.78N/00648.33E_076/000g002t053r000p003P003b10146h78L206.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291050z5217.78N/00648.33E_013/001g004t053r000p003P003b10146h77L342.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291100z5217.78N/00648.33E_261/001g004t054r000p003P003b10146h74L576.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291110z5217.78N/00648.33E_084/001g004t055r000p003P003b10145h71L648.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291120z5217.78N/00648.33E_062/001g006t057r000p003P003b10143h69L490.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@291130z5217.78N/00648.33E_050/001g004t057r000p003P003b10143h70L251.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291140z5217.78N/00648.33E_167/001g004t056r000p003P003b10142h70L391.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291150z5217.78N/00648.33E_104/001g003t056r000p003P003b10142h69L494.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@291200z5217.78N/00648.33E_036/001g007t057r000p003P003b10141h69L458.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291210z5217.78N/00648.33E_114/001g004t057r000p003P003b10140h67L537.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291220z5217.78N/00648.33E_335/001g005t057r000p003P003b10139h67L511.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291230z5217.78N/00648.33E_044/001g007t057r000p003P003b10138h68L617.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291240z5217.78N/00648.33E_030/000g004t058r000p003P003b10138h67L447.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291250z5217.78N/00648.33E_111/001g004t057r000p003P003b10137h68L263.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291300z5217.78N/00648.33E_086/001g006t057r000p003P003b10138h70L258.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291310z5217.78N/00648.33E_262/001g005t056r000p003P003b10138h67L295.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291320z5217.78N/00648.33E_178/001g003t056r000p003P003b10137h66L359.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291330z5217.78N/00648.33E_187/001g003t056r000p003P003b10137h67L353.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291340z5217.78N/00648.33E_271/002g005t056r000p003P003b10137h67L382.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291350z5217.78N/00648.33E_046/001g004t056r000p003P003b10137h69L239.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291400z5217.78N/00648.33E_253/001g004t056r000p003P003b10137h68L242.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291410z5217.78N/00648.33E_267/001g004t056r000p003P003b10137h67L313.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291420z5217.78N/00648.33E_175/001g003t056r000p003P003b10137h70L343.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291430z5217.78N/00648.33E_227/001g004t056r000p003P003b10137h70L258.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291440z5217.78N/00648.33E_202/001g004t055r000p003P003b10136h70L284.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291450z5217.78N/00648.33E_246/000g003t055r000p003P003b10136h69L334.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291500z5217.78N/00648.33E_270/001g004t056r000p003P003b10135h68L333.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@291510z5217.78N/00648.33E_245/001g004t056r000p003P003b10136h68L233.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291520z5217.78N/00648.33E_256/001g004t056r000p003P003b10136h69L145.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@291530z5217.78N/00648.33E_236/000g003t055r000p003P003b10136h71L274.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291540z5217.78N/00648.33E_153/001g005t055r000p003P003b10136h70L236.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291550z5217.78N/00648.33E_211/000g002t055r000p003P003b10135h69L155.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291600z5217.78N/00648.33E_253/001g004t055r000p003P003b10135h71L101.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291610z5217.78N/00648.33E_281/000g003t054r000p003P003b10134h72L106.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291620z5217.78N/00648.33E_264/000g003t054r000p003P003b10134h72L114.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291630z5217.78N/00648.33E_281/000g004t054r000p003P003b10133h73L148.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291640z5217.78N/00648.33E_246/000g003t054r000p003P003b10133h73L113.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291650z5217.78N/00648.33E_069/001g005t054r000p003P003b10134h72L035.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291700z5217.78N/00648.33E_134/000g003t053r000p003P003b10134h75L041.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291710z5217.78N/00648.33E_071/001g004t052r000p003P003b10134h76L065.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291720z5217.78N/00648.33E_052/000g002t052r000p003P003b10134h76L066.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291730z5217.78N/00648.33E_084/000g002t052r000p003P003b10134h75L080.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291740z5217.78N/00648.33E_069/000g001t052r000p003P003b10134h76L077.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291750z5217.78N/00648.33E_102/000g001t052r000p003P003b10134h74L065.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291800z5217.78N/00648.33E_063/001g003t053r000p003P003b10134h73L057.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291810z5217.78N/00648.33E_051/000g003t052r000p003P003b10134h74L043.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291820z5217.78N/00648.33E_041/000g002t052r000p003P003b10134h74L030.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291830z5217.78N/00648.33E_038/001g004t052r000p003P003b10134h73L017.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@291840z5217.78N/00648.33E_032/000g003t052r000p003P003b10135h74L012.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291850z5217.78N/00648.33E_062/000g003t051r000p003P003b10135h73L014.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291900z5217.78N/00648.33E_.../000g000t051r000p003P003b10134h74L014.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291910z5217.78N/00648.33E_232/000g002t051r000p003P003b10135h74L010.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@291920z5217.78N/00648.33E_060/000g002t051r000p003P003b10135h75L006.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@291930z5217.78N/00648.33E_.../000g000t051r000p003P003b10135h76L005.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@291940z5217.78N/00648.33E_.../000g000t050r000p003P003b10135h77L002.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@291950z5217.78N/00648.33E_056/000g001t050r000p003P003b10135h78L001.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@292000z5217.78N/00648.33E_050/000g001t050r000p003P003b10135h78L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@292010z5217.78N/00648.33E_.../000g000t050r000p003P003b10135h78L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@292020z5217.78N/00648.33E_203/000g002t050r000p003P003b10135h78L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292030z5217.78N/00648.33E_.../000g000t050r000p003P003b10134h77L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@292040z5217.78N/00648.33E_343/000g002t050r000p003P003b10135h75L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@292050z5217.78N/00648.33E_246/000g002t050r000p003P003b10135h74L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@292100z5217.78N/00648.33E_.../000g000t050r000p003P003b10134h74L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@292110z5217.78N/00648.33E_020/000g002t050r000p003P003b10134h74L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@292120z5217.78N/00648.33E_.../000g000t049r000p003P003b10134h76L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292130z5217.78N/00648.33E_352/000g002t049r000p003P003b10134h76L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@292140z5217.78N/00648.33E_.../000g000t049r000p003P003b10134h77L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292150z5217.78N/00648.33E_.../000g000t049r000p003P003b10134h78L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@292200z5217.78N/00648.33E_345/000g002t049r000p003P000b10134h78L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@292210z5217.78N/00648.33E_.../000g000t049r000p003P000b10134h79L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@292220z5217.78N/00648.33E_.../000g000t049r000p003P000b10134h79L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@292230z5217.78N/00648.33E_022/000g002t049r000p003P000b10134h80L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@292240z5217.78N/00648.33E_.../000g000t048r000p003P000b10134h81L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292250z5217.78N/00648.33E_.../000g000t048r000p003P000b10134h81L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@292300z5217.78N/00648.33E_.../000g000t048r000p003P000b10133h82L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@292310z5217.78N/00648.33E_.../000g000t048r000p003P000b10134h82L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@292320z5217.78N/00648.33E_.../000g000t047r000p003P000b10133h82L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292330z5217.78N/00648.33E_.../000g000t047r000p003P000b10133h83L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@292340z5217.78N/00648.33E_.../000g000t047r000p003P000b10133h83L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@292350z5217.78N/00648.33E_.../000g000t046r000p003P000b10133h84L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300000z5217.78N/00648.33E_.../000g000t046r000p003P000b10133h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300010z5217.78N/00648.33E_.../000g000t045r000p003P000b10132h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@300020z5217.78N/00648.33E_.../000g000t045r000p003P000b10132h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300030z5217.78N/00648.33E_.../000g000t045r000p003P000b10132h87L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@300040z5217.78N/00648.33E_.../000g000t045r000p003P000b10132h87L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@300050z5217.78N/00648.33E_.../000g000t046r000p003P000b10131h87L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@300100z5217.78N/00648.33E_.../000g000t046r000p003P000b10130h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@300110z5217.78N/00648.33E_.../000g000t046r000p003P000b10131h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300120z5217.78N/00648.33E_.../000g000t046r000p003P000b10131h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@300130z5217.78N/00648.33E_.../000g000t...r000p003P000b.....h...weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300140z5217.78N/00648.33E_047/000g001t046r000p003P000b10130h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@300150z5217.78N/00648.33E_.../000g000t046r000p003P000b10129h86L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300200z5217.78N/00648.33E_.../000g000t046r000p003P000b10129h87L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300210z5217.78N/00648.33E_.../000g000t046r000p003P000b10128h87L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300220z5217.78N/00648.33E_.../000g000t045r000p003P000b10128h88L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300230z5217.78N/00648.33E_.../000g000t045r000p003P000b10127h89L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300240z5217.78N/00648.33E_.../000g000t044r000p003P000b10128h90L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300250z5217.78N/00648.33E_.../000g000t044r000p003P000b10127h91L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300300z5217.78N/00648.33E_.../000g000t044r000p003P000b10127h91L000.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@300310z5217.78N/00648.33E_.../000g000t044r000p003P000b10128h91L001.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300320z5217.78N/00648.33E_276/000g001t044r000p003P000b10128h90L002.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300330z5217.78N/00648.33E_118/000g001t045r000p003P000b10128h89L005.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300340z5217.78N/00648.33E_.../000g000t045r000p003P000b10128h89L010.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300350z5217.78N/00648.33E_.../000g000t045r000p003P000b10129h89L014.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@300400z5217.78N/00648.33E_.../000g000t044r000p003P000b10129h90L020.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300410z5217.78N/00648.33E_.../000g000t044r000p003P000b10129h90L020.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300420z5217.78N/00648.33E_.../000g000t044r000p002P000b10128h91L024.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300430z5217.78N/00648.33E_.../000g000t044r000p002P000b10129h91L037.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300440z5217.78N/00648.33E_.../000g000t044r000p002P000b10129h92L049.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300450z5217.78N/00648.33E_120/000g001t044r000p002P000b10129h91L086.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-1:@300500z5217.78N/00648.33E_312/000g002t045r000p002P000b10130h89L126.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-3:@300510z5217.78N/00648.33E_276/000g001t046r000p002P000b10130h87L131.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300520z5217.78N/00648.33E_316/000g002t046r000p002P000b10131h86L104.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300530z5217.78N/00648.33E_330/000g002t047r000p002P000b10132h85L100.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300540z5217.78N/00648.33E_323/000g002t047r000p002P000b10132h84L123.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300550z5217.78N/00648.33E_285/000g002t048r000p002P000b10132h82L140.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300600z5217.78N/00648.33E_245/000g001t048r000p002P000b10132h82L150.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-6:@300610z5217.78N/00648.33E_333/000g003t049r000p002P000b10132h82L161.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-4:@300620z5217.78N/00648.33E_008/000g003t049r000p002P000b10133h79L222.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-5:@300630z5217.78N/00648.33E_307/000g003t050r000p002P000b10133h77L379.weewx-4.7.0-WeatherFlowUDP <br>
EW0725>APRS,TCPXX*,qAX,CWOP-7:@300640z5217.78N/00648.33E_326/000g003t051r000p002P000b10133h76L240.weewx-4.7.0-WeatherFlowUDP <br>
</BODY>
</HTML>
Means that using a lua-file or python-file we need another way to get the CWOP data-lists:
=> a different plan of attack is required to read the url, convert the result to txt-type-file and subsequently extract the last line and it's contents.
An alternative url-call resulting in nice html-table provides a 'real' html-page with a very simple HTML-table included, covering last 24 hours, with UTC-info to full extend and the meteo-values already translated into metric units. If you reduce the url-call, you get a table with 'imperial' units.
In this setup with the actual values in the first/top dataline of the table.
Easier for web-scraping software?
Principally not in favour of webscraping, but don't see an alternative, simple approach to get to the CWOP-data.
June01, 2022:
2 Latest messages merged, and last deleted
Posted: Wednesday 01 June 2022 21:15
by Toulon7559
Applying the url mentioned in the previous message as basis, in this message a basic Python3.x-script which
- calls the url giving a CWOP-datafile in HTML-format
- reads the CWOP-datafile
- extracts the weatherdata
- corrects the extracted data for expected applications for mainland Europe.
To make it running, the settings in this script are linked to an operational personal CWOP-station:
;-) NO responsibility & liability whatever
- that the data from this station is of good quality & continuous, and
- that the info from it is suitable&safe for your applications!!!!!!
Use is at own risk, and data resulting from the datafile should not to be used elsewhere!!!!!!!
For YOUR personal use YOU must adjust the geographical location (in line 059) and the CWOP-callsign (in line 081).
Under that condition, further application of the script is left to the ideas/wishes of the user.
However, the script below is only useful as feasability-demonstration,
because it is not clever in the perspective of value-extraction (with manual counting of positions within the dataline).
Based on present experience it certainly needs another method of determining the substring-positions in the extraction-segment.
Argument is that the datafields in the webpage have variable length and all 'separators' are identical:
- the 'separators' cannot be applied for finding specific data-lines and data-types
- when low or negative temperatures occur, it causes a change of length of the temp-value (which unfortunately is in the front of the dataline).
- wind direction and wind speed may have variation in length from 1 digit to 3 digits [because no leading 0's for small values]
- rain-values may be either 4 or 5 characters long for the same reason
=> the search for substringpositions must become capable to deal with variable length of value-fields
etc.
#!/usr/bin/python3
# -*- coding = utf-8 to enable reading by simple editors -*-
# (c)2022 script compiled by Toulon7559 from various material from forums for application with Python3.x
# Version 00_220601, reading Info-table from CWOP-account, extracting values and standardizing
# Extraction based on setup as described at https://realpython.com/beautiful-soup-w ... er-python/
# Line 006 Description of setup
# For file-extraction for a specific station mandatorily required to have CWOP_CallSign for that specific station,
# CWOP_Documentation = https://weather.gladstonefamily.net/CWOP_Guide.pdf
# Setup for data-extraction, compilation & upload:
# 0. Install module pyEphem to get info on sunrise and sunset, and module requests for http-handling.
# 1. Read & Extract Weather Data from CWOP (= specific url-call)
# 2. Use extracted data for conversion as required to get SI-units,
# Overall script running interval to be realised by a cronjob: set running of that cronjob at the interval selected below or shorter.
# Assuming daily quotum of 500 url-calls,
# don't set the general script interval shorter than 5 minutes => 24*12 = 288 calls/24hours, leaving some spare quotum for other CWOP-callers.
# Line 018 = PREPARATION & SETTING
# Imports for script-operation
import requests # used for handling of http-requests
# Line 023
print ('Start of script CWOP_READER000')
DEBUG = 1 # DEBUG=0 is 'operational running without print'
# the "print"-lines only added for local read-out e.g. during script_tuning
# Line 029 = PREPARATION FOR HANDLING DATE&TIME
import calendar
import datetime # used for timestamps & timecheck
import time # used for timestamps & delays
from datetime import datetime, timedelta
now = datetime.now()
now_utc = datetime.utcnow()
dattim1 = datetime.now().strftime('%Y%m%d %H:%M')
dattim2 = datetime.now().strftime('%Y%m%d%H%M%S')
dattim3 = datetime.utcnow().strftime('%Y%m%d%H%M%S')
if DEBUG == 1:
print
print ('Present Date&Time (CET) = ', now)
print ('Present DatTim1 (CET) = ', dattim1)
print ('Present DatTim2 (CET) = ', dattim2)
print ('Present DatTim3 (UTC) = ', dattim3)
print
# Line 049 = EXTRACT SUNRISE & SUNSET
import ephem
#import datetime # already imported above
# Presetting of parameters
sun = ephem.Sun()
home = ephem.Observer()
home.lat, home.lon = '52.2962647', '6.80555' # YOUR lat, long # ADAPT TO YOUR STATION-LOCATION !!!!!!!!
# lat/long-info must be inserted as decimal degrees
sun.compute(home)
sunrise, sunset = (home.next_rising(sun), home.next_setting(sun))
sunrise_localtime, sunset_localtime = ephem.localtime(sunrise), ephem.localtime(sunset)
daylightminutes = (sunset_localtime - sunrise_localtime) * 1440 # find how many minutes of daylight today
# sunriselessonemin = ephem.date(sunrise + 1*ephem.minute)
if DEBUG == 1:
print ('= Sunrise & Sunset expressed in UTC! =')
print ('Sunrise = ',sunrise)
print ('Sunset = ',sunset)
print ('= Sunrise & Sunset expressed in Local time! =')
print ('Sunrise = ',sunrise_localtime)
print ('Sunset = ',sunset_localtime)
# Line 075 = READ Weather-Information BY url-calls to the CWOP_Server
# Login Info for CWOP-account
# CWOP_CallSign = "AB0123" # ADAPT for Station_CallSign => URL1 yet to be adapted for parameterized setup !!!!!!!!
# Example call-string for HTML-reportpage from CWOP = http://www.findu.com/cgi-bin/wx.cgi?cal ... its=metric
URL1 = "http://www.findu.com/cgi-bin/wx.cgi?cal ... its=metric"
page = requests.get(URL1)
a = page.text
if DEBUG == 1:
# print(a)
print
print ('End of reading datafile')
# Line 089 = EXTRACT Actual Weather-Information from the HTML-file
# Station_CallSign used as initial reference
# Next positions found by dumb counting of positions in the string
print(a.find("mb"))
print(a.index("mb"))
start_index = a.find("mb")
time_start = start_index + 37
print(time_start)
time_end = start_index + 51
print(time_end)
time_UTC = a[844:858]
print('time_UTC = ', time_UTC)
temp_start = time_end + 26
print(temp_start)
temp_end = temp_start + 3
print(temp_end)
tempC = a[884:887]
print('tempC = ',tempC)
wd_start = temp_end + 27
print(wd_start)
wd_end = wd_start + 4
print(wd_end)
windD = a[914:918]
print('windD = ',windD)
ws_start = wd_end + 26
print(ws_start)
ws_end = ws_start + 4
print(ws_end)
windS = a[943:947]
print('windS = ',windS)
wg_start = ws_end + 25
print(wg_start)
wg_end = wg_start + 4
print(wg_end)
windG = a[973:977]
print('windG = ',windG)
r1h_start = wg_end + 25
print(r1h_start)
r1h_end = r1h_start + 5
print(r1h_end)
rain1h = a[1002:1007]
print('rain1h = ',rain1h)
r24h_start = r1h_end + 25
print(r24h_start)
r24h_end = r24h_start + 5
print(r24h_end)
rain24h = a[1032:1037]
print('rain24h = ',rain24h)
rtoday_start = r24h_end + 25
print(rtoday_start)
rtoday_end = rtoday_start + 5
print(r1h_end)
rain_today = a[1062:1067]
print('rainToday = ',rain_today)
hum_start = rtoday_end + 25
print(hum_start)
hum_end = hum_start + 3
print(hum_end)
relhum = a[1092:1095]
print('relhum = ',relhum)
baro_start = hum_end + 25
print(baro_start)
baro_end = baro_start + 7
print(baro_end)
baro = a[1120:1127]
print('baro = ',baro)
print
print('Summary from extraction:')
print('time_UTC = ',time_UTC)
print('windD (deg) = ',windD)
print('windS (kmh) = ',windS)
print('windG (kmh) = ',windG)
print('rain1h (cm) = ',rain1h)
print('rain24h (cm) = ',rain24h)
print('rainToday (cm) = ',rain_today)
print('relhum (%) = ',relhum)
print('baro (mb) = ',baro)
print
print ('End of extraction of data')
# Line xxx = Collection & Correction of values
# Corrections
print
print('Corrected values:')
print('CWOPtime_UTC = ',time_UTC)
print('localtime_CET = ',dattim2)
print('Sunrise = ',sunrise_localtime)
print('Sunset = ',sunset_localtime)
rainrate = 10 * float(rain1h)
print('rain1h (mm) = ',rainrate)
rain24h = 10 * float(rain24h)
print('rain24h (mm) = ',rain24h)
rain_today = 10 * float(rain_today)
# but this is rain since 00:00UTC, not rain since 00:00CET !
print('rainToday (mm) = ',rain_today)
print('baro (hPa/MSL) = ',baro)
print
print ('Here is reserved space for applications')
print
print ('End of script CWOP_Reader000')
Posted: Monday 06 June 2022 7:34
by Toulon7559
Meanwhile built a new Python3.x-script operating on this url having fixed-format data-contents, including a datafeed aimed at HetWeerActueel.
This script will be published in this message after clean-up.
In practise the format of the data-table is less fixed than expected, requiring some 'corrective measures' while webscraping.
Addition 2024, 2nd of June:
Due to mods & extensions & detected variations the script meanwhile has grown too big to publish in this forum.
Because of the mutations due to differences at CWOP in APRS_RawData, probably also not easy to put a 'common'version in Github.
Posted: Monday 03 June 2024 0:35
by Toulon7559
Further application & development breeds some 'surprises'.
If feeding a geolocation to PyEphem with too many decimals, the output values for e.g. sunrisetime and sunsettime become 'foolish'.
Further experience with PyEphem also signals that this Python-module is sensitive to the type and to the application of other data-inputs:
some data must be textstrings, other data must be number, but unclear what&when&how ......
This example shows that various inputs are possible, but nowhere a description to be found [?] for setup&application of such inputs.
Any users with knowledge how to deal with setup of PyEphem for generation of sunrise and sunset for a given geolocation and given meteo-setup?
For correct understanding:
Geolocation in this case is NOT my own location, but might be some other place on earth and input data & output data is required for pythonic application.
If own location is applicable and sunrise&sunset required for Domoticz, then much easier to directly ask Domoticz.
Or can Domoticz be tweaked to occasionally provide info on sunrise&sunset for another, remote location?
