ZigBeeForDomoticZ fatal signal 11
Posted: Thursday 28 April 2022 10:04
I have a fresh install. Only install domoticz (on RPi) and the ZigBeeForDomoticZ plugin.
After a restart have the following errors and the system does not start.
Any idea?
Any idea?
Current thread 0x6e8ff200 (most recent call first):
File "/home/rpiadmin/domoticz/plugins/Domoticz-Zigbee/Classes/AdminWidgets.py", line 102 in createStatusWidget
File "/home/rpiadmin/domoticz/plugins/Domoticz-Zigbee/Classes/AdminWidgets.py", line 31 in __init__
File "/home/rpiadmin/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 405 in onStart
File "/home/rpiadmin/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1658 in onStart
2022-04-28 09:37:51.618 Error: Domoticz(pid:4374, tid:4388('Zigbee')) received fatal signal 11 (Segmentation fault)
2022-04-28 09:37:51.618 Error: siginfo address=0x1116, address=(nil)
2022-04-28 09:37:54.097 Error: Did not find stack frame for thread (LWP 4388)), printing full gdb output:
2022-04-28 09:37:54.097 Error: > [New LWP 4376]
2022-04-28 09:37:54.097 Error: > [New LWP 4377]
2022-04-28 09:37:54.097 Error: > [New LWP 4378]
2022-04-28 09:37:54.097 Error: > [New LWP 4379]
2022-04-28 09:37:54.097 Error: > [New LWP 4380]
2022-04-28 09:37:54.097 Error: > [New LWP 4381]
2022-04-28 09:37:54.097 Error: > [New LWP 4382]
2022-04-28 09:37:54.097 Error: > [New LWP 4383]
2022-04-28 09:37:54.097 Error: > [New LWP 4384]
2022-04-28 09:37:54.097 Error: > [New LWP 4385]
2022-04-28 09:37:54.097 Error: > [New LWP 4386]
2022-04-28 09:37:54.098 Error: > [New LWP 4387]
2022-04-28 09:37:54.098 Error: > [New LWP 4388]
2022-04-28 09:37:54.098 Error: > [New LWP 4389]
2022-04-28 09:37:54.098 Error: > [New LWP 4390]
2022-04-28 09:37:54.098 Error: > [New LWP 4391]
2022-04-28 09:37:54.098 Error: > [New LWP 4392]
2022-04-28 09:37:54.098 Error: > [New LWP 4393]
2022-04-28 09:37:54.098 Error: > [Thread debugging using libthread_db enabled]
2022-04-28 09:37:54.098 Error: > Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
2022-04-28 09:37:54.098 Error: > 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e8772f8, req@entry=0x7e8772f0, rem=0x7e877308, rem@entry=0x7e877300) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.098 Error: > 52 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: No such file or directory.
2022-04-28 09:37:54.098 Error: > Id Target Id Frame
2022-04-28 09:37:54.098 Error: > * 1 Thread 0x76ef5240 (LWP 4374) "domoticz" 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e8772f8, req@entry=0x7e8772f0, rem=0x7e877308, rem@entry=0x7e877300) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.098 Error: > 2 Thread 0x7586f200 (LWP 4376) "Watchdog" 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7586eb70, req@entry=0x7586eb68, rem=0x7586eb80, rem@entry=0x7586eb78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.098 Error: > 3 Thread 0x7506e200 (LWP 4377) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 4 Thread 0x7486d200 (LWP 4378) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 5 Thread 0x73a32200 (LWP 4379) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 6 Thread 0x73231200 (LWP 4380) "Webem_ssncleane" 0x768b363c in epoll_wait (epfd=14, events=0x73230358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.099 Error: > 7 Thread 0x72a30200 (LWP 4381) "WebServer_8080" 0x768b363c in epoll_wait (epfd=10, events=0x72a2f328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.099 Error: > 8 Thread 0x720ff200 (LWP 4382) "Webem_ssncleane" 0x768b363c in epoll_wait (epfd=21, events=0x720fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.099 Error: > 9 Thread 0x718fe200 (LWP 4383) "WebServer_443" 0x768b363c in epoll_wait (epfd=17, events=0x718fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.099 Error: > 10 Thread 0x70eff200 (LWP 4384) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 11 Thread 0x706fe200 (LWP 4385) "TCPServer" 0x768b363c in epoll_wait (epfd=24, events=0x706fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.099 Error: > 12 Thread 0x6fcff200 (LWP 4386) "MainWorker" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 13 Thread 0x6f4fe200 (LWP 4387) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f4fdb80, clockid=<optimized out>, expected=0, futex_word=0xa8e3b0 <m_mainworker+3984>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.099 Error: > 14 Thread 0x6e8ff200 (LWP 4388) "Zigbee" 0x7687a4d4 in __GI___wait4 (pid=4394, stat_loc=0x6ea25380, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2022-04-28 09:37:54.099 Error: > 15 Thread 0x6e0fe200 (LWP 4389) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6e0fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa8de7c <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.099 Error: > 16 Thread 0x6d6ff200 (LWP 4390) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.099 Error: > 17 Thread 0x6cefe200 (LWP 4391) "EventSystemQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6cefdac0, clockid=<optimized out>, expected=0, futex_word=0xa8d57c <m_mainworker+348>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.099 Error: > 18 Thread 0x6c6fd200 (LWP 4392) "Plugin_ASIO" futex_wait_cancelable (private=0, expected=0, futex_word=0x1817330) at ../sysdeps/nptl/futex-internal.h:186
2022-04-28 09:37:54.100 Error: > 19 Thread 0x6b5ff200 (LWP 4393) "Zigbee" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6b5fe248, clockid=<optimized out>, expected=0, futex_word=0x75d6a9e8 <_PyRuntime+256>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.100 Error: > Thread 19 (Thread 0x6b5ff200 (LWP 4393) "Zigbee"):
2022-04-28 09:37:54.100 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6b5fe248, clockid=<optimized out>, expected=0, futex_word=0x75d6a9e8 <_PyRuntime+256>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.100 Error: > #1 __pthread_cond_wait_common (abstime=0x6b5fe248, clockid=<optimized out>, mutex=0x0, cond=0x75d6a9c0 <_PyRuntime+216>) at pthread_cond_wait.c:520
2022-04-28 09:37:54.100 Error: > #2 __pthread_cond_timedwait (cond=0x75d6a9c0 <_PyRuntime+216>, mutex=0x0, abstime=0x6b5fe248) at pthread_cond_wait.c:656
2022-04-28 09:37:54.100 Error: > #3 0x75a22e90 in ?? () from /lib/arm-linux-gnueabihf/libpython3.9.so
2022-04-28 09:37:54.100 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.100 Error: > Thread 18 (Thread 0x6c6fd200 (LWP 4392) "Plugin_ASIO"):
2022-04-28 09:37:54.100 Error: > #0 futex_wait_cancelable (private=0, expected=0, futex_word=0x1817330) at ../sysdeps/nptl/futex-internal.h:186
2022-04-28 09:37:54.100 Error: > #1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0x1817308) at pthread_cond_wait.c:508
2022-04-28 09:37:54.100 Error: > #2 __pthread_cond_wait (cond=0x1817308, mutex=0x0) at pthread_cond_wait.c:638
2022-04-28 09:37:54.100 Error: > #3 0x003d727c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2022-04-28 09:37:54.100 Error: > #4 0x00683e74 in Plugins::BoostWorkers() ()
2022-04-28 09:37:54.101 Error: > #5 0x0077d374 in thread_proxy ()
2022-04-28 09:37:54.101 Error: > #6 0x769ef300 in start_thread (arg=0x6c6fd200) at pthread_create.c:477
2022-04-28 09:37:54.101 Error: > #7 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.101 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.101 Error: > Thread 17 (Thread 0x6cefe200 (LWP 4391) "EventSystemQueu"):
2022-04-28 09:37:54.101 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6cefdac0, clockid=<optimized out>, expected=0, futex_word=0xa8d57c <m_mainworker+348>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.101 Error: > #1 __pthread_cond_wait_common (abstime=0x6cefdac0, clockid=<optimized out>, mutex=0x6cefda60, cond=0xa8d550 <m_mainworker+304>) at pthread_cond_wait.c:520
2022-04-28 09:37:54.101 Error: > #2 __pthread_cond_timedwait (cond=0xa8d550 <m_mainworker+304>, mutex=0x6cefda60, abstime=0x6cefdac0) at pthread_cond_wait.c:656
2022-04-28 09:37:54.101 Error: > #3 0x00213404 in CEventSystem::EventQueueThread() ()
2022-04-28 09:37:54.101 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.101 Error: > #5 0x769ef300 in start_thread (arg=0x6cefe200) at pthread_create.c:477
2022-04-28 09:37:54.101 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.101 Error: > Thread 16 (Thread 0x6d6ff200 (LWP 4390) "EventSystem"):
2022-04-28 09:37:54.102 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.102 Error: > #1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2022-04-28 09:37:54.102 Error: > #2 0x0020a438 in CEventSystem::Do_Work() ()
2022-04-28 09:37:54.102 Error: > #3 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.102 Error: > #4 0x769ef300 in start_thread (arg=0x6d6ff200) at pthread_create.c:477
2022-04-28 09:37:54.102 Error: > #5 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.102 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.102 Error: > Thread 15 (Thread 0x6e0fe200 (LWP 4389) "NotificationSys"):
2022-04-28 09:37:54.102 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6e0fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa8de7c <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.102 Error: > #1 __pthread_cond_wait_common (abstime=0x6e0fdbb0, clockid=<optimized out>, mutex=0x6e0fdb58, cond=0xa8de50 <m_mainworker+2608>) at pthread_cond_wait.c:520
2022-04-28 09:37:54.102 Error: > #2 __pthread_cond_timedwait (cond=0xa8de50 <m_mainworker+2608>, mutex=0x6e0fdb58, abstime=0x6e0fdbb0) at pthread_cond_wait.c:656
2022-04-28 09:37:54.102 Error: > #3 0x00277298 in CNotificationSystem::QueueThread() ()
2022-04-28 09:37:54.102 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.102 Error: > #5 0x769ef300 in start_thread (arg=0x6e0fe200) at pthread_create.c:477
2022-04-28 09:37:54.102 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.103 Error: >
2022-04-28 09:37:54.103 Error: > Thread 14 (Thread 0x6e8ff200 (LWP 4388) "Zigbee"):
2022-04-28 09:37:54.103 Error: > #0 0x7687a4d4 in __GI___wait4 (pid=4394, stat_loc=0x6ea25380, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2022-04-28 09:37:54.103 Error: > #1 0x0029121c in dumpstack_gdb(bool) ()
2022-04-28 09:37:54.103 Error: > #2 0x002917e8 in signal_handler(int, siginfo_t*, void*) ()
2022-04-28 09:37:54.103 Error: > #3 <signal handler called>
2022-04-28 09:37:54.103 Error: > #4 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-04-28 09:37:54.103 Error: > #5 <signal handler called>
2022-04-28 09:37:54.103 Error: > #6 0x00000014 in ?? ()
2022-04-28 09:37:54.103 Error: > #7 0x758f247c in _PyEval_EvalFrameDefault () from /lib/arm-linux-gnueabihf/libpython3.9.so
2022-04-28 09:37:54.103 Error: > #8 0x6b92bdd0 in ?? ()
2022-04-28 09:37:54.103 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.103 Error: > Thread 13 (Thread 0x6f4fe200 (LWP 4387) "MainWorkerRxMsg"):
2022-04-28 09:37:54.103 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f4fdb80, clockid=<optimized out>, expected=0, futex_word=0xa8e3b0 <m_mainworker+3984>) at ../sysdeps/nptl/futex-internal.h:323
2022-04-28 09:37:54.104 Error: > #1 __pthread_cond_wait_common (abstime=0x6f4fdb80, clockid=<optimized out>, mutex=0x769eaa1c, cond=0xa8e388 <m_mainworker+3944>) at pthread_cond_wait.c:520
2022-04-28 09:37:54.104 Error: > #2 __pthread_cond_timedwait (cond=0xa8e388 <m_mainworker+3944>, mutex=0x769eaa1c, abstime=0x6f4fdb80) at pthread_cond_wait.c:656
2022-04-28 09:37:54.104 Error: > #3 0x00263724 in MainWorker::Do_Work_On_Rx_Messages() ()
2022-04-28 09:37:54.104 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.104 Error: > #5 0x769ef300 in start_thread (arg=0x6f4fe200) at pthread_create.c:477
2022-04-28 09:37:54.104 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.104 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.104 Error: > Thread 12 (Thread 0x6fcff200 (LWP 4386) "MainWorker"):
2022-04-28 09:37:54.104 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.104 Error: > #1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2022-04-28 09:37:54.104 Error: > #2 0x0025f5fc in MainWorker::Do_Work() ()
2022-04-28 09:37:54.104 Error: > #3 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.104 Error: > #4 0x769ef300 in start_thread (arg=0x6fcff200) at pthread_create.c:477
2022-04-28 09:37:54.104 Error: > #5 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.105 Error: >
2022-04-28 09:37:54.105 Error: > Thread 11 (Thread 0x706fe200 (LWP 4385) "TCPServer"):
2022-04-28 09:37:54.105 Error: > #0 0x768b363c in epoll_wait (epfd=24, events=0x706fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.105 Error: > #1 0x003d519c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2022-04-28 09:37:54.105 Error: > #2 0x003d7194 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2022-04-28 09:37:54.105 Error: > #3 0x006e0d80 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
2022-04-28 09:37:54.105 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.105 Error: > #5 0x769ef300 in start_thread (arg=0x706fe200) at pthread_create.c:477
2022-04-28 09:37:54.105 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.105 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.105 Error: > Thread 10 (Thread 0x70eff200 (LWP 4384) "Scheduler"):
2022-04-28 09:37:54.105 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.105 Error: > #1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2022-04-28 09:37:54.105 Error: > #2 0x00288690 in CScheduler::Do_Work() ()
2022-04-28 09:37:54.105 Error: > #3 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.106 Error: > #4 0x769ef300 in start_thread (arg=0x70eff200) at pthread_create.c:477
2022-04-28 09:37:54.106 Error: > #5 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.106 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.106 Error: > Thread 9 (Thread 0x718fe200 (LWP 4383) "WebServer_443"):
2022-04-28 09:37:54.106 Error: > #0 0x768b363c in epoll_wait (epfd=17, events=0x718fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.106 Error: > #1 0x003d519c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2022-04-28 09:37:54.106 Error: > #2 0x003d7194 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2022-04-28 09:37:54.106 Error: > #3 0x0072bc88 in http::server::server_base::run() ()
2022-04-28 09:37:54.106 Error: > #4 0x002d9bfc in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#280}> > >::_M_run() ()
2022-04-28 09:37:54.106 Error: > #5 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.106 Error: > #6 0x769ef300 in start_thread (arg=0x718fe200) at pthread_create.c:477
2022-04-28 09:37:54.106 Error: > #7 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.106 Error: > Thread 8 (Thread 0x720ff200 (LWP 4382) "Webem_ssncleane"):
2022-04-28 09:37:54.107 Error: > #0 0x768b363c in epoll_wait (epfd=21, events=0x720fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.107 Error: > #1 0x003d519c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2022-04-28 09:37:54.107 Error: > #2 0x003d7194 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2022-04-28 09:37:54.107 Error: > #3 0x006fc0b4 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2022-04-28 09:37:54.107 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.107 Error: > #5 0x769ef300 in start_thread (arg=0x720ff200) at pthread_create.c:477
2022-04-28 09:37:54.107 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.107 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.107 Error: > Thread 7 (Thread 0x72a30200 (LWP 4381) "WebServer_8080"):
2022-04-28 09:37:54.107 Error: > #0 0x768b363c in epoll_wait (epfd=10, events=0x72a2f328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.107 Error: > #3 0x0072bc88 in http::server::server_base::run() ()
2022-04-28 09:37:54.107 Error: > #4 0x002d9bfc in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#280}> > >::_M_run() ()
2022-04-28 09:37:54.107 Error: > #5 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.107 Error: > #6 0x769ef300 in start_thread (arg=0x72a30200) at pthread_create.c:477
2022-04-28 09:37:54.108 Error: > #7 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.108 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.108 Error: > Thread 6 (Thread 0x73231200 (LWP 4380) "Webem_ssncleane"):
2022-04-28 09:37:54.108 Error: > #0 0x768b363c in epoll_wait (epfd=14, events=0x73230358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2022-04-28 09:37:54.108 Error: > #1 0x003d519c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2022-04-28 09:37:54.108 Error: > #2 0x003d7194 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2022-04-28 09:37:54.108 Error: > #3 0x006fc0b4 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2022-04-28 09:37:54.108 Error: > #4 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.108 Error: > #5 0x769ef300 in start_thread (arg=0x73231200) at pthread_create.c:477
2022-04-28 09:37:54.108 Error: > #6 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.108 Error: > Thread 5 (Thread 0x73a32200 (LWP 4379) "InfluxPush"):
2022-04-28 09:37:54.108 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.108 Error: > #1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2022-04-28 09:37:54.108 Error: > #2 0x00393ed0 in CInfluxPush::Do_Work() ()
2022-04-28 09:37:54.108 Error: > #3 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.108 Error: > #4 0x769ef300 in start_thread (arg=0x73a32200) at pthread_create.c:477
2022-04-28 09:37:54.108 Error: > #5 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.108 Error: > Thread 4 (Thread 0x7486d200 (LWP 4378) "PluginMgr"):
2022-04-28 09:37:54.108 Error: > #2 0x00684684 in Plugins::CPluginSystem::Do_Work() ()
2022-04-28 09:37:54.108 Error: > #4 0x769ef300 in start_thread (arg=0x7486d200) at pthread_create.c:477
2022-04-28 09:37:54.109 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-04-28 09:37:54.109 Error: > Thread 3 (Thread 0x7506e200 (LWP 4377) "SQLHelper"):
2022-04-28 09:37:54.109 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2022-04-28 09:37:54.109 Error: > #1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2022-04-28 09:37:54.109 Error: > #2 0x002a8698 in CSQLHelper::Do_Work() ()
2022-04-28 09:37:54.109 Error: > #3 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.109 Error: > #4 0x769ef300 in start_thread (arg=0x7506e200) at pthread_create.c:477
2022-04-28 09:37:54.109 Error: > #5 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.109 Error: > Thread 2 (Thread 0x7586f200 (LWP 4376) "Watchdog"):
2022-04-28 09:37:54.109 Error: > #0 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7586eb70, req@entry=0x7586eb68, rem=0x7586eb80, rem@entry=0x7586eb78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.109 Error: > #1 0x76874080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7586ebb0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2022-04-28 09:37:54.109 Error: > #2 0x7687a830 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2022-04-28 09:37:54.109 Error: > #3 0x00224e2c in sleep_milliseconds(long) ()
2022-04-28 09:37:54.109 Error: > #4 0x00291950 in Do_Watchdog_Work() ()
2022-04-28 09:37:54.109 Error: > #5 0x00906734 in execute_native_thread_routine ()
2022-04-28 09:37:54.109 Error: > #6 0x769ef300 in start_thread (arg=0x7586f200) at pthread_create.c:477
2022-04-28 09:37:54.109 Error: > #7 0x768b3208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2022-04-28 09:37:54.109 Error: > Thread 1 (Thread 0x76ef5240 (LWP 4374) "domoticz"):
2022-04-28 09:37:54.109 Error: > #0 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e8772f8, req@entry=0x7e8772f0, rem=0x7e877308, rem@entry=0x7e877300) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.109 Error: > #1 0x76874080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7e877338) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2022-04-28 09:37:54.109 Error: > #3 0x00224d98 in sleep_seconds(long) ()
2022-04-28 09:37:54.109 Error: > #4 0x001af740 in main ()
2022-04-28 09:37:54.110 Error: >
2022-04-28 09:37:54.110 Error: > Main thread:
2022-04-28 09:37:54.110 Error: > #0 0x76873f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7e8772f8, req@entry=0x7e8772f0, rem=0x7e877308, rem@entry=0x7e877300) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2022-04-28 09:37:54.110 Error: > #1 0x76874080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0x7e877338) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2022-04-28 09:37:54.110 Error: > #2 0x7687a830 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2022-04-28 09:37:54.110 Error: > #3 0x00224d98 in sleep_seconds(long) ()
2022-04-28 09:37:54.110 Error: > #4 0x001af740 in main ()
2022-04-28 09:37:54.110 Error: > [Inferior 1 (process 4374) detached]
