IKEA lights not joinning
Posted: Thursday 21 April 2022 18:49
by usky73
Hi all
I am stuck on IKEA Tradfi light association...
I have the remote control.
I try to follow the procedure here :
https://github.com/zigbeefordomoticz/wi ... ts_Ikea.md
Means 6 times On/Off and launch a the pairing with the zigate interface. But nothing has been found. I repeat it many times without success.
Any help is welcome !
Re: IKEA lights not joinning
Posted: Thursday 21 April 2022 19:00
It is the correct way but sometimes they will not listen.... Keep trying. The bulb will flash when in pairing mode.
The bulb also needs to be close to the zigate ( 1 or 2 meters) while pairing.
Posted: Thursday 21 April 2022 21:26
by pipiche
Some time the 6 times Off / On ( and not On/Off) you need to finish on the On needs a particular cadence ...
Posted: Saturday 23 April 2022 12:53
by usky73
Thanks both.
I have done both things without success... in the beginning but I found the solution. I hate Ikea.
I am using GU10 lights with the remote control.
I was doing 6 times On/Off with the remote control, even Off/On did not work.
The solution is to switch Off/On 6 times with a real switch !
Last issue not solved, I have created a group with the 3 lights in Domoticz with the max power.
But when using the group switch, the light will switch on but not 100%.
If I go to the switch menu, I can see it full power, but it is not the reality. If I move the power down and up then I have the light for real full.
Any idea ?
