Location in Nginx conf not redirecting
Broke
Post by Broke »
So after countless hours of trying and testing different configurations i have managed to get Nginx Reversed Proxy working.
I wanted a reversed proxy because of DZGA automatically started instead of changing the credentials in Google every time with a restart.
I have made an "A" DNS at No-ip
But now i am pulling my hair out. When type in a location like: location /domoticz {
proxy_set_header Host $host;
It will redirect at the NGINX welcome page. Is it because i have a free DNS domain name?? Do i need wildcards?? I am just guessing.
This is the config file i use.
server {
    listen 80;
    listen [::]:80;
    server_name my.ddns.net;
    #change to match your address
    return 301 https://$server_name$request_uri;
server {
        listen 448 ssl http2;
        listen [::]:448 ssl http2;
        ssl_certificate /etc/letsencrypt/live/my.ddns.net/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/my.ddns.net/privkey.pem;
        ssl on;
        ssl_session_cache  builtin:1000  shared:SSL:10m;
        ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
        ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
        ssl_prefer_server_ciphers on;
        location / {
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Scheme $scheme;
                proxy_pass http://localhost:11631; #Local ipno to dzga
                proxy_read_timeout  90;
Re: Location in Nginx conf not redirecting
I am no expert on this but did you see the wiki page https://www.domoticz.com/wiki/WebServer_Proxy
