[Features Request] Extra field (disabled) in Notification tab
jmcvieira
Domoticz version: 2024.6
Post by jmcvieira »
Hello I added some Esp 8266 board´s to my old electric heaters and brought them back to the 21st century with centralized control from Domoticz, now spring has arrived and it's time to put them away in the pantry, I created a notification on each one of them, case one goes offline or overheat I get notified, it would be nice to have a checkbox to deactivate this notification, keeping all the parameters for the next fall to be easier to reactivate the notification once you put the heaters on back up and running, thank you all for this great software.
Screenshot 2022-04-14 at 16-11-02 Domoticz.png (130.71 KiB) Viewed 376 times
Re: [Features Request] Extra field (disabled) in Notification tab
For the short term as long as the enable/disable checkbox is not implemented try the following:
Disable all Active Notification systems on the notification so you will not be notified.
So in your case disable Browser, Email and pushbullet too.
jmcvieira
Post by jmcvieira »
Tank you that´s a good idea, but Domoticz requires one notification Active Systems to be checked, if you uncheck all Active Systems,
and click update Domoticz activates all Active Systems, i cleared my browser cache but the behavior is the same.
So i left one notification Active Systems checked, it´s that or delete the task.
Thank´s
thanks
Jose Vieira
