Timer plan improvement suggestion
Patricen
Domoticz version: Beta rel
Post by Patricen »
Hello all,
I've mentioned that when changing from one timer plan to another one, the current timer settings are kept until there is a change in the newly selected timer plan.
An example: controlling heating using 17.5° setpoint from 23:00 to 6:00 and 19° from 6:00 to 23:00 on one timer plan(a), and 16° / 17° at the same times on a second timer plan (b).
If I do change timer plan from a to b at 7:00, setpoint will stay 19° until 23:00 to switch to 16° and back to 17° at 6:00, same issue switching from b to a.
Would it be possible to set the setpoints or any timer controlled device to the current status upon timer plan change to avoid this kind of issue?
