Setting a thermostat
Posted: Friday 08 April 2022 4:38
by Alain
I've been using Blockly for quite a while to run all sorts of scripts in our home and that has been quite successful. The problem I ran into with Blockly is that you can't automatically set a thermostat value, so I'm switching over to dzVents and trying to do it from there. My problem:
I have recently bought a new heat pump. I can set the water supply setpoint through Modbus. This works quite well. I have a dummy thermostat setup and when I change the value, it relays it through Modbus to the heat pump controller and it runs up to the requested temperature. What I want to do, however, is use the requested supply temperature from my Plugwise Anna thermostat and write that value into the dummy thermostat.
I have set up the following script:
local MODE = 745 -- switch device
local SETPOINT_DEVICE = 744 -- Dummy thermostat
local SUPPLY_TEMPERATURE = 216 -- Supply temperature
local LOGGING = true
return
on =
devices =
SUPPLY_TEMPERATURE,
MODE
if (device.name == SUPPLY_TEMPERATURE) then
domoticz.devices(744).updateSetPpoint = domoticz.devices.SUPPLY_TEMPERATURE
I'm not getting any errors, but the setpoint is not changing. Can someone point me in the right direction to change the code so that when idx 216 gets a new value, it will be copied to idx 744?
Re: Setting a thermostat
Posted: Friday 08 April 2022 11:17
by plugge
You've made typo and a programming error.
Replace: domoticz.devices(744).updateSetPpoint = domoticz.devices.SUPPLY_TEMPERATURE
With: domoticz.devices(744).updateSetPoint(domoticz.devices.SUPPLY_TEMPERATURE)
Posted: Friday 08 April 2022 19:51
by Alain
plugge wrote: Friday 08 April 2022 11:17
Thanks Plugge, however, it still isn't updating the thermostat device. I'm not getting any error. It says that device 216 has a new value and displays that but there is no updating of device 744 to have the same value as 216.
Posted: Friday 08 April 2022 20:23
by plugge
Alain wrote: Friday 08 April 2022 19:51
Your rule will not fire because the if statement compares a device name with a number. That doesn't match, so, no error.
Take a look at the manual:
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
(BTW: uppercase is used for dzVents constants. To avoid confusion you should lowercase for variables.)
Could you try this:
return
on =
devices =
SUPPLY_TEMPERATURE,
MODE
-- assuming SUPPLY_TEMPERATURE is the triggering device
-- if MODE is triggered, then your rule will not fire
-- see the log for the following print statements
print('==============your script==================')
print(' device.name: '..device.name)
print(' SUPPLY_TEMPERATURE name: '..domoticz.devices(SUPPLY_TEMPERATURE).name
if device.name == domoticz.devices(SUPPLY_TEMPERATURE).name
then
print(' ==============> Rule fired!')
domoticz.devices(744).updateSetPoint(domoticz.devices(SUPPLY_TEMPERATURE).temperature)
Posted: Saturday 09 April 2022 9:37
by Alain
plugge wrote: Friday 08 April 2022 20:23
Could you try this:
return
on =
devices =
SUPPLY_TEMPERATURE,
MODE
then
Your suggestion works! Now I'm going to look over it carefully (with the wiki on hand) to see where my train of thought when wrong. I want to master this code because I have many automations in my home that are now limited because I'm using Blockly.
Posted: Saturday 09 April 2022 18:59
by Alain
I know that MODE won't fire it, but I thought it would be best to start as simple as possible to get a feel for dzVents first. Once I have figured out how this works, I'm going to try and include MODE in the "if" statement.
