LSC Smart Connect power plug
cornelis
Post by cornelis »
I have bought a LSC smart connect power plug. According to the information on the box, it is compatible with Alexa, Hey google and Siri. I have just updated my domoticz running on a Raspberry pi. Thereafter I tried to setup this switch. But I cannot find it in the type list. Any suggestions?
Greetings from Holland,
Cornelis
Derik
Re: LSC Smart Connect power plug
Post by Derik »
perhap something with tuya convert
https://www.twoenter.nl/blog/domotica/l ... a-convert/
Only LSC did change the chip.... some working fine othe never..
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
cornelis wrote: Saturday 02 April 2022 16:04 Hi,
Cornelis
You have to install Tuya on your phone, create an account and add the plug.
After that, you need to add Tuya (in Domoticz => Hardware).
Derik
Post by Derik »
robgeerts wrote: Monday 20 June 2022 10:11
Cornelis
No
There are new types not all are suported...
First check before you buy
robgeerts
Post by robgeerts »
Derik wrote: Monday 20 June 2022 18:05
Cornelis
No
What No?
You dont know if he installed Tuya?
The one he has is working here, if you install it via Tuya > Domoticz (unless he has other version)
Derik
Post by Derik »
robgeerts wrote: Monday 20 June 2022 18:07
No
What No?
Ok perhaps to fast no.
Only the best is first check this and read this..
When the chip is new tuyaconvert is not working any more.
So you save a lot of time:
https://templates.blakadder.com/lsc_sma ... _plug.html
robgeerts
Post by robgeerts »
Derik wrote: Monday 20 June 2022 19:41
No
What No?
I dont think he is working with tuyaconvert yet. I think its his first switch in this brand and didnt work with tuya in any way yet. Thats why i said he just needs to install Tuya app and connect to domoticz via login :)
Derik
Post by Derik »
robgeerts wrote: Monday 20 June 2022 20:04
What No?
Yes i understand...
Only with the wrong chip you can try what u want
Unfort.. not working a lot of Tuya convert any more
robgeerts
Post by robgeerts »
Derik wrote: Monday 20 June 2022 20:28
Yes i understand...
Sure, but i dont see any reason to use tuyaconvert in this case.
Only if you dont wanna use Tuya/SmartLife, which doesnt bother me personally. As once installed you never need tuya anymore ;)
Xenomes
Domoticz version: 2025.2
Post by Xenomes »
Hi Cornelis,
There is a cloud plugin for Tuya devices. https://github.com/Xenomes/Domoticz-TUYA-Plugin
more information see viewtopic.php?t=33145
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
