script not triggering...WHY????
tiga
Post by tiga »
i have a script that updates a dummy electrical counter (device is called "huidig verbruik").
this script works perfect
local elektriciteit = 'elektriciteit'
local idxhuidigverbruik = 7039
local blanco = 0
if devicechanged[elektriciteit] then
        sgebruik_hoog_tarief, sgebruik_laag_tarief, slevering_hoog_tarief, slevering_laag_tarief, sinkoop, slevering = otherdevices_svalues[elektriciteit]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
        sgebruik_hoog_tarief = tonumber(sgebruik_hoog_tarief)
        sgebruik_laag_tarief = tonumber(sgebruik_laag_tarief)
        slevering_hoog_tarief = tonumber(slevering_hoog_tarief)
        slevering_laag_tarief = tonumber(slevering_laag_tarief)
        sinkoop = tonumber(sinkoop)
        slevering = tonumber(-slevering)
        --print(sgebruik_hoog_tarief)
        --print(sgebruik_laag_tarief)
        --print(slevering_hoog_tarief)
        --print(slevering_laag_tarief)
        --print(sinkoop)
        --print(slevering)
        if sinkoop >0 then
            commandArray = {['UpdateDevice'] = idxhuidigverbruik .. '|0|' .. tostring(sinkoop) .. ';' .. tostring(blanco)}
        if sinkoop ==0 then
            commandArray = {['UpdateDevice'] = idxhuidigverbruik .. '|0|' .. tostring(slevering) .. ';' .. tostring(blanco)}
but when i want to trigger an other lua (device based) script with the "huidig verbruik" device i can not get it to trigger.
something like this does not work:
if devicechanged['huidig verbruik'] then ........
why does it not work?
jvdz
Domoticz version: 4.107
Re: script not triggering...WHY????
Post by jvdz »
Pretty sure that an updatedevice operation on sensors in LUA will not trigger the event system and don't think you can change that.
I believe dzevent does have the option to trigger the event system when updating a sensor or else you need to use the API interface with a JSON call to update.
tiga
Post by tiga »
the strange thing is that the first script works perfect.
that is the reading i get from my energy meter.
jvdz
Post by jvdz »
Why is that strange? I assume it is a device from a regular hardware definition so one expect the eventsystem to trigger an event.
