Good morning smart people,
I get the error message below and I'm looking for a solution but can't find an explanation.
Anyone know what's going on here?
logbook Domoticz:
2022-03-28 10:10:17.717 Error: MQTT Discovery: Call to function 'onMessage' failed, exception details:
2022-03-28 10:10:17.720 Error: MQTT Discovery: Traceback (most recent call last):
2022-03-28 10:10:17.720 Error: MQTT Discovery: File "/home/pi/domoticz/plugins/domoticz_mqtt_discovery/plugin.py", line 392, in onMQTTPublish
2022-03-28 10:10:17.720 Error: MQTT Discovery: message = json.loads(rawmessage.decode('utf8'))
2022-03-28 10:10:17.720 Error: MQTT Discovery: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb5 in position 264: invalid start byte
2022-03-28 10:10:17.720 Error: MQTT Discovery: During handling of the above exception, another exception occurred:
2022-03-28 10:10:17.720 Error: MQTT Discovery: File "/home/pi/domoticz/plugins/domoticz_mqtt_discovery/plugin.py", line 1116, in onMessage
2022-03-28 10:10:17.720 Error: MQTT Discovery: _plugin.onMessage(Connection, Data)
2022-03-28 10:10:17.720 Error: MQTT Discovery: File "/home/pi/domoticz/plugins/domoticz_mqtt_discovery/plugin.py", line 379, in onMessage
2022-03-28 10:10:17.720 Error: MQTT Discovery: self.mqttClient.onMessage(Connection, Data)
2022-03-28 10:10:17.720 Error: MQTT Discovery: File "/home/pi/domoticz/plugins/domoticz_mqtt_discovery/plugin.py", line 151, in onMessage
2022-03-28 10:10:17.720 Error: MQTT Discovery: self.mqttPublishCb(topic, Data['Payload'])
2022-03-28 10:10:17.720 Error: MQTT Discovery: File "/home/pi/domoticz/plugins/domoticz_mqtt_discovery/plugin.py", line 395, in onMQTTPublish
2022-03-28 10:10:17.720 Error: MQTT Discovery: message = rawmessage.decode('utf8')
please help
MQTT Discovery hickup Topic is solved
- rolandtwilt
- Domoticz version: 2026.3
Re: MQTT Discovery hickup
You are using the mqtt_discover python plugin, not the new MQTT Autodiscover hardware https://www.domoticz.com/wiki/MQTT#Add_ ... Gateway.22
So if you want support for this plugin go to the topic viewtopic.php?t=21918
or make an issue in the github repository (if not already created) https://github.com/emontnemery/domoticz_mqtt_discovery
