Text not updating
EdwinK
Text not updating
Post by EdwinK »
I see this in my debug-log file
2022-03-31 11:20:05.155 Debug: MQTT Auto Disc: Topic: domoticz/in, Message: {"command":"udevice","idx":190,"nvalue":2,"svalue":"Kans op gladheid door sneeuwval."}
Bur when I look at device 190 I notice that it last update was March 6.
this is what I have in Node-Red.
        "id": "37cc8291989eb8a8",
        "type": "tab",
        "label": "MeteoAlarm KNMI",
        "disabled": false,
        "info": "",
        "env": []
        "id": "6c6dcd5fb912ade7",
        "type": "http request",
        "z": "37cc8291989eb8a8",
        "name": "",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://cdn.knmi.nl/knmi/xml/rss/rss_KNMIwaarschuwingen.xml",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "x": 350,
        "y": 160,
        "wires": [
                "74b6e54b66b937f2"
        "id": "206e54fce96bfcf8",
        "type": "inject",
        "name": "10 Minute tick",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 160,
        "wires": [
                "6c6dcd5fb912ade7"
        "id": "74b6e54b66b937f2",
        "type": "xml",
        "name": "",
        "property": "payload",
        "attr": "",
        "chr": "",
        "x": 530,
        "y": 160,
        "wires": [
                "f1c7fef468771b6a"
        "id": "f1c7fef468771b6a",
        "type": "function",
        "name": "Function",
        "func": "var i;\nvar desc;\nvar mod_desc;\nvar al_txt;\nvar no_al_txt;\nfor (i = 0; i < msg.payload.rss.channel[0].item.length; i++) {\n    if (msg.payload.rss.channel[0].item[i].title[0] === \"Waarschuwingen Zuid-Holland\") {\n        desc = msg.payload.rss.channel[0].item[i].description[0];\n        mod_desc = desc.replace(/(<([^>]+)>)/ig, '.'); // Modified description without HTML tags. Tags replaced by . (dot)\n        no_al_txt = mod_desc.substring((mod_desc.indexOf(\".\") + 2), (mod_desc.indexOf(\".\", (mod_desc.indexOf(\".\") + 1)) + 1));\n        al_txt = mod_desc.substring((mod_desc.indexOf(\"..\") + 2), (mod_desc.indexOf(\"..\", (mod_desc.indexOf(\"..\") + 1)) + 1));\n    }\n}\nswitch (desc.substring(5,desc.indexOf(\".\"))) {\n    case \"Groen\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 190, \"nvalue\": 1, \"svalue\": no_al_txt };\n        break;\n\n   case \"Geel\" :\n        msg.payload = { \"command\": \"udevice\", \"idx\": 190, \"nvalue\": 2, \"svalue\": al_txt };\n        break;\n\n    case \"Oranje\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 190, \"nvalue\": 3, \"svalue\": al_txt };\n        break;\n\n    case \"Rood\":\n        msg.payload = { \"command\": \"udevice\", \"idx\": 190, \"nvalue\": 4, \"svalue\": al_txt };\n        break;\n\n    default:\n        msg.payload = { \"command\": \"udevice\", \"idx\": 190, \"nvalue\": 0, \"svalue\": \"No Data available\" };\n        break;\n}\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 160,
        "wires": [
                "5b307902260f6b0a"
        "id": "5b307902260f6b0a",
        "type": "mqtt out",
        "name": "Domoticz In",
        "topic": "domoticz/in",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "2d06e6e96ce54335",
        "x": 890,
        "y": 160,
        "wires": []
        "id": "cae751d6c4047878",
        "type": "comment",
        "name": "Meteoalarm KNMI",
        "info": "",
        "x": 570,
        "y": 100,
        "wires": []
        "id": "2d06e6e96ce54335",
        "type": "mqtt-broker",
        "name": "MQTT_Server",
        "broker": "192.168.0.11",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
FireWizard
Re: Text not uodating
Post by FireWizard »
Hello @EdwinK,
If I look to your debug file, I see:
The Node RED flow for KNMI Weather Alarm has never been prepared to use Auto Discovery and will not work as the topic is "domoticz/in"
The message (at least today) is correct and should be send every 10 minutes.
What have you done on March 6? Did you configure MQTT Auto Discovery on that date?
Check that.
EdwinK
Re: Text not updating
Post by EdwinK »
O. I didn't know that it couldn't be used with the autodiscovery plugin. So, if I use the normal MQTT plugin it should work?
Can't remember what I did on that day, but i'll try to figure it out.
FireWizard
Hello @EdwinK,
YES
I never made that to be used by Auto Discovery. That requires a specific topic structure,
EdwinK
Post by EdwinK »
Okay,. Well, I just found out it indeed does. Guess that I learn every day ;) Next thing is to see if there is a 'Pollen alert' system somewhere to use in Domoticz ;)
FireWizard
Hi@EdwinK
There is: https://hooikoortsradar.nl/ or https://pollennieuws.nl/ or https://www.hooikoortsalert.nl/
