WiZ switches stops working if one WiZ lamp is disconnected/borken
LordMax
Domoticz version: 2021.1
Post by LordMax »
Hi!
Ive had a problem where when a WiZ lamp gets disconnected every WiZ lamp stops working.. Is there an updated version of this script or is there a way to prevent this? Ive tried checking the code and logs but the logs are pretty weak and doesnt tell you much where it crashes..
Thanks in advance!
Best regards Max
Re: WiZ switches stops working if one WiZ lamp is disconnected/borken
Hi, at what script are you referring to?
