Dashticz v3 is loading...
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
I updated my dashticz last week from 3.9.1 to the latest 3.9.3. All my devices can load the dashticz dashboard except for my ancient ipad mini1
Now the things is I have exactly the same issue as with the last update; "Dashticz v3 is loading" on a white screen. Last time I totally messed up my whole Domoticz server because I couldn't get it solved pulling all my hair. After a full restore from a previous version and updating dashticz to the latest version it was all working (that was 3.9.1).
Now last week I updated to 3.9.3 and the same issue is here again.
I tried the following
First tried all kinds of ways to clear cache and history on the iPad
rebooted iPad (ipad mini A1432 with 16GB, 12GB free)
rebooted Router (MikroTik)
rebooted Domoticz server (raspberry pi)
cleaned up docker containers, stopped and started container, dubblechecked docker Makefile.ini
tried different browsers on iPad (default Safari, Kios pro lite, Dolphin
renamed custom.js and custom.css so its not used
tried to start with /?cfg=CONFIG_DEFAULT.js
tried with and without password in CONFIG.js
tried different network password/segment
As you can see I'm running out of options. I do see some error messages in develoipmode in Firefox:
<html class=" non-touch" lang="en"> EVENT						<-- inline: 5
html {
  font-size: 10px;
  -webkit-tap-highlight-color: rgba(0,0,0,0);  <-- invalid property name
html {						<-- inline: 5
  font-family: sans-serif;
  -ms-text-size-adjust: 100%;  <-- invalid property name
  -webkit-text-size-adjust: 100%;  <-- invalid property value
<body id="page-top" class="night" style="overflow": auto; user-select: none;" unselectable="on"> EVENT SCROLL OVERFLOW
body {						<-- creative.css
  webkit-tap-highlight-color: #222222;
The above is from the latest firefox on linux Ubuntu 20.04LTS
Could it be that because of the old browsers it doesnt't support these errors?
Also what I find very strange is that if i load the dashboard (first/start page of domoticz i dont see any icons, on Setup-device i get this:
{{::"Loading..." | translate }}
So i have a strong feeling that it is some sort of cache issue but whatever i tried I'm not able to solve it on the ipad itself
On another ipad (ipad2, a liiiiitle bit newer but also an oldie) its working.
Big difference is that the ipad mini (that gives this issue) is always turned on and connected to dashticz
Is there in any way an option with a url command to force clear cache or with an .js command or can I somehow sent a command from dashticz or domoticz?
It seems that after I got my domoticz re-installed that dashticz also worked again last time.
Any indicators would be awesome, otherwise probably have to buy a new ipad and use the ipad2 as dashboard
If any more info is needed please let me know
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Lokonli
Re: Dashticz v3 is loading...
Post by Lokonli »
I think it's caused by caching of the start page (index.html). In Dashticz 3.9.2 I've implemented a mechanism to prevent this.
So hopefully this will be the last difficult update for you...
What you can try to do is to load Dashticz with some dummy parameters in the url. This will prevent caching, like:
http://dashticz-ip:port/?test=1
Lokonli
Post by Lokonli »
What is the iOS and Safari version of your iPad 1?
Maikel76
Post by Maikel76 »
Hi Lokonli,
The test=1 url unfortunately doesn't work
My ipad version is: iOS: 9.3.5 (13G36) latest possible version, it's the 16GB version and there is 12GB free
Safari is part of iOS thus same version
Javascript slider/option is on
Thanks a lot in advance
Lokonli
Post by Lokonli »
And Dashticz 3.9.1 was working?
Maikel76
Post by Maikel76 »
Lokonli wrote: Wednesday 16 March 2022 16:30 And Dashticz 3.9.1 was working?
Hi Lokonli,
Yes I indeed had version 3.8.9 running after the backup and succesfully updated and running 3.9.1
After that I updated domoticz to version 2022.1 (latest stable) and dashticz was still working.
I then updated to dashticz 3.9.3 a few days later and got the white screen since then
Musje
Post by Musje »
Maikel76 wrote: Thursday 17 March 2022 8:52
Hi Lokonli,
Hi Maikel,
I had this problem once before and in my case i checked the custom folder and found out that i was missing my config files. Copying them back from my backup to the folder solved it for me.
Maikel76
Post by Maikel76 »
Musje wrote: Friday 18 March 2022 8:07
Hi Lokonli,
Hi Maikel,
Hi Musje,
Thanks for the tip. Dashticz custom files are backuped my my script every day and where put after the restore. Somehow this seems to be a specific iOS issue in combination with javascript/dashticz. Lokonli is helping me, hopefully we get it solved.
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
Hope you share it here, i have the same problem.
Lokonli
Post by Lokonli »
What kind of iOS device do you use? OS version?
Which Dashticz version?
Is Dashticz master working?
Verstuurd vanaf mijn AC2003 met Tapatalk
StefanDomoticz
Post by StefanDomoticz »
edwin1234 wrote: Friday 18 March 2022 20:33 Hope you share it here, i have the same problem.
Hier zelfde probleem.
Ipad aan de muur betreft ipad mini met oude niet updatebare ios.
Maar ook via docker krijg ik na update niet meer aan de praat.
Alles wat via devices benaderd wordt werkt!
erg vreemd
Lokonli
Post by Lokonli »
erg vreemd
Can you test the Dashticz master version? If that's still working I can solve it.
Lokonli
Post by Lokonli »
StefanDomoticz wrote: Saturday 19 March 2022 20:32
erg vreemd
Can you test latest beta version?
It should work ...
edwin1234
Post by edwin1234 »
I did sudo git pull and restarted docker, but still it hangs on dashticz is loading....
If i refresh the page i get 408 request time out, Server timeout waiting for the HTTP request from the client.
Lokonli
Post by Lokonli »
Check:
https://dashticz.readthedocs.io/en/beta ... out-errors
Maikel76
(SOLVED)Re: Dashticz v3 is loading...
Post by Maikel76 »
My problem is solved with the new beta version, thanks a lot Lokonli ! :)
edwin1234
Post by edwin1234 »
My error is also solved, its working now :D
Thank u very much
Lokonli
Post by Lokonli »
edwin1234 wrote:My error is also solved, its working now :D
Thank u very much
Great!
