Dashticz v3.9.3 beta
Posted: Wednesday 09 March 2022 22:15
by Lokonli
New functionality:
- Up/down dials for Thermostats, Blinds and Dimmers.
With the up/down buttons you can adjust the values step by step.
- thermtempupdown.jpg (10.07 KiB) Viewed 3026 times
Just add the following block parameter:
- Wind devices can be rendered with a needle indicating wind speed and wind gust instead of wind direction
- windspeed.jpg (26.17 KiB) Viewed 3026 times
subtype: 'windspeed' //to display wind speed
subtype: 'windgust' //to display wind gust
For all changes see:
https://dashticz.readthedocs.io/en/beta ... a-9-3-2022
Re: Dashticz v3.9.3 beta
Posted: Thursday 10 March 2022 12:56
by jake
Nice update
Posted: Thursday 10 March 2022 22:51
by Krenstik
I love a thermostat....
Posted: Thursday 10 March 2022 23:23
by Krenstik
Well, maybe one idea, use this style of the dial for the selector? Especially in my case, I have more selections and in the dial is not so nice as a list is too long....
So use up and down buttons to move between values.
Posted: Friday 11 March 2022 7:47
by Doudy
Lokonli wrote: Wednesday 09 March 2022 22:15
New functionality:
[*] Wind devices can be rendered with a needle indicating wind speed and wind gust instead of wind direction
subtype: 'windspeed' //to display wind gust
small correction
Posted: Friday 11 March 2022 10:23
by Lokonli
Krenstik wrote: Thursday 10 March 2022 23:23
Good idea. I've added it to the list. I'll add a parameter indicating whether the selected option should be activated directly, or only after pressing the middle button. Time-out value before activation probably could work as well.
Posted: Monday 14 March 2022 22:30
by Musje
hey,
I've update to the latest beta v3.9.3 and for some reason my garbage collector isn't working anymore.
I've got the error: Error loading garbage data undefined
I've got nothing changed in my config.
I make use of the compagny Rova
Has it something to do with the latest version or is it something else?
Thanks in advance
Posted: Tuesday 15 March 2022 7:23
by Lokonli
Musje wrote: Monday 14 March 2022 22:30
hey,
Thanks in advance
My Rova test address is still working. Can you send me your zipcode+housenumber, then I can check that as well. (By PM if you prefer that)
Posted: Sunday 03 April 2022 8:24
by sailmich
Nice I've updated to latest beta and found subtype updown for blinds. When I want to set my blinds to a certain percentage I have to touch it eg eight times and after each time I had changed the value for 10% I have to wait until the blind is reaching the position. Is it somehow possible to change the design or the way to choose a certain percentage? Wait 5 seconds before sending the new value? Stop is not working with my Fibaro FGR222!
Thanks again for your great work
Posted: Sunday 03 April 2022 19:24
by besix
You can change the default 10% to a different value. Use steps in the block definition. Example for 20%
blocks[161] = {title: 'Roleta',
type:'dial',
subtype: 'updown',
steps: 20,
inverted: false,
width:6}
Posted: Sunday 03 April 2022 19:32
by sailmich
Thanks besix for your answer, but in my eyes just increase percentage doesn't make it more practical. What I would like to have is something similar to a slider or maybe four sections open/close/x percentage/y percentage. Unfortunately my programming skills are zero.
Cheer's
Posted: Monday 04 April 2022 20:20
by Lokonli
sailmich wrote: Sunday 03 April 2022 8:24
I'll add a block parameter to configure the delay before the position command will be send.
Posted: Tuesday 05 April 2022 9:11
by sailmich
Lokonli wrote: Monday 04 April 2022 20:20
That would be great!
Posted: Friday 28 October 2022 21:14
by sailmich
sailmich wrote: Tuesday 05 April 2022 9:11
May I ask if it's still on your agenda?
Cheers
Posted: Wednesday 16 November 2022 17:30
by Lokonli
sailmich wrote: Friday 28 October 2022 21:14
Cheers
Yes, It's your lucky day
I've implemented it in latest beta.
Add the 'delay' block parameter to your dial block definition, and it will delay the device updates from Domoticz with the indicated number of seconds after the last interaction.
Can you test?
Posted: Wednesday 23 November 2022 14:02
by sailmich
Sorry for late reply but I was in Saudi Arabia for a few weeks. Just came Back Yesterday, will try later today.
Posted: Wednesday 23 November 2022 18:45
by sailmich
Lokonli wrote: Wednesday 16 November 2022 17:30
Cheers
Can you test?
First thank you very much for your big improvements!
I tried your new settings and it's working but I have some minor issues.
When touching plus or minus the blind starts immediately moving, but I still can change the percentage while moving.
From readthedocs
For Blinds the middle button will work as stop button.
I have Fibaro roller shutter, it seems they doesn't support stop function for blinds. When press stop the blind changing the direction and then stop at random position, might be better to deactivated the stop function?
With the inverted block parameter you can invert the values: 10% will become 90%, 70% will become 30%, etc.
I prefer that for an Up Down blinds dial the Up-button will open the blinds. The blinds percentage goes from 0% (fully closed) to 100% (fully open).
This conflicts with the defaults in Domoticz where 0 is open, and 100 is closed.
For this reason the ‘inverted’ block parameter by default is set to true for regular Domoticz blinds devices, and set to false for Domoticz Blinds Inverted devices.
I use dashticz on a wall mounted Fire HD tablet. On all mobiles in my family we use Domoticz app. Therefore I would prefer how it is in Domoticz. Also does the graphic in Domoticz symbolized a blind and showing where the position of the blind is. Maybe you could add a block parameter for plus and minus direction? When using a inverted blind from Domoticz, your inverted block parameter doesn't do a change! When using a blind dial, press up let my blinds go down and vice versa.
I hope I did write it understandable
Cheers
