Cannot add temperature humidity sensor to dashboard
Posted: Thursday 24 February 2022 8:43
by averter
I have a temperature humidity sensor on Domoticz "temperature" tab, that is receiving measurements from a script in my raspberry pi. All is working fine, except that when I click on the Add to/Remove from Dashboard star button nothing happens, i.e., the device is not added to the dashboard. I have tested and I am able to add other devices to the dashboard.
This is the device info
8 ESP 14058 1 Temperature Humidity Temp + Humidity THGN122/123/132, THGR122/228/238/268 0, 14.0;39.0 -
and ESP is a "dummy" device. Thank you in advance for any help.
Re: Cannot add temperature humidity sensor to dashboard
Posted: Thursday 24 February 2022 12:21
And if you just create a new temp/hum sensor from the ESP Dummy device, can you put that on the dashboard?
The sensor does not need to be filled with data. You can delete it after the test.
Posted: Wednesday 02 March 2022 9:15
by averter
waltervl wrote: Thursday 24 February 2022 12:21 And if you just create a new temp/hum sensor from the ESP Dummy device, can you put that on the dashboard?
Indeed, I can add it to the dashboard in this way
Posted: Wednesday 02 March 2022 9:19
by averter
Interestingly, as soon as I start sending data to it from the raspberry it does not display on the dashboard anymore. Hmmm :?
I am sending the data using domoticz API/JSON URL's https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
Posted: Wednesday 02 March 2022 9:37
by averter
Solved it. I forgot to add the humidity STATUS to the url. Thanks for your help @waltervl
Posted: Wednesday 02 March 2022 9:40
Good that it is solved. Thanks for the feedback!
