Using library with asyncio
Posted: Monday 21 February 2022 17:52
by Filip
I am developing a plugin based on a library that uses the python library asyncio.
My plugin uses already the treading mechanism as explained in https://github.com/domoticz/domoticz/bl ... hreaded.py.
From the asyncio documentation, it is clear that this can be used even in a thread by just using the asyncio.run() statement.
However when doing this, I always got an error "there is no current event loop in thread", while for the asyncio.run() there is no need to initialize a loop.
Any idea?
My thread-function looks like (concept)
    def handleTasks(self):
        Domoticz.Debug('Entering tasks handler')
        try:
            while True:
                task = self.tasksQueue.get(block=True)
                if task is None:
                    Domoticz.Debug('Exiting task handler')
                    self.tasksQueue.task_done()
                    break
                Domoticz.Debug('Handling task: {}.'.format(task['Action']))
                if task['Action'] == 'Login':
                    try:
                        asyncio.run(my_routine_using_asyncio())
                    except Exception as err:
                        Domoticz.Debug('Login error: {}'.format(err))
Re: Using library with asyncio
Posted: Monday 21 February 2022 17:59
by pipiche
We are using thread and asyncio extensively you might want to look here where we start the asyncio part
https://github.com/zigbeefordomoticz/Do ... ead.py#L73
Posted: Sunday 01 June 2025 18:00
by Filip
I am already suffering a while from a strange behavior. Just as example, I have 2 plugins: 1) BMW and 2) Husvqarna.
Husqvarna is using httpx (httpx.Client() - synchronous sessions). The BMW plugin is based on the bimmer_connected library, using httpx.AsyncClient() and asyncio.
All is running fine! Except when restarting the Husqvarna plugin, there are problems with the BMW plugin communication (managed by the bimmer_connected library).
In order to understand what is happening I used - by experiment - asyncio also in the bmw plugin:
___asyncio_plugin.py.txt
(58.99 KiB) Downloaded 33 times
In this implementation, the asyncio event loop is running in a thread inside the plugin, starting my main task by:
self.async_loop.run_until_complete(self.async_main_task())
And the strange thing that happens when restarting the Husqvarna plugin, the asyncio event loop is closed. And even more strange is that the task (self.async_main_task()) itself is not finished, meaning that it cannot cause the end of the loop due "run_until_complete". This is proven as there is not any logging showing that the self.async_main_task() ends.
2025-05-31 22:04:44.456 BMW X1: Asyncio event loop is about to close.
2025-05-31 22:04:44.457 BMW X1: Asyncio loop closed in isolated thread.
2025-05-31 22:04:44.457 BMW X1: Event loop cleared from thread context.
2025-05-31 22:04:44.457 BMW X1: Asyncio thread function finished.
In my understanding the Domoticz plugin management leads to threads being terminated or asyncio loops becoming unusable without Python-level exceptions.
Has anyone else faced such behavior? Is this a problem in Domoticz?
Thanks for your thoughts!
Currently the only workaround that I apply is restarting the BMW plugin after the Husqvarna plugin restarted.
However I would hope getting the root cause of the problem solved (if possible).
Btw: I have a third plugin that is using the Domoticz API with httpx (no sessions, just httpx.get()) and this has the same effect on the BMW plugin/bimmer_connected.
Posted: Sunday 01 June 2025 18:38
by pipiche
With the plugin Zigbee4Domoticz we are also using asyncio via the zigpy library fully relying on it.
what we are doing is to start a dedicated thread here https://github.com/zigbeefordomoticz/Do ... ead.py#L84
and then the thread create a new loop here https://github.com/zigbeefordomoticz/Do ... ead.py#L95
Hope it helps
Posted: Sunday 01 June 2025 19:37
by Filip
Thanks for your feedback.
This is exactly the principle I used... Start a thread --> creates the loop --> start the task with run_until_complete --> in my cased the task is running in endless loop to get instructions through queue...
(58.99 KiB) Downloaded 49 times
  • L430: create thread
  • L647: create loop (in thread)
  • L653: async_loop.run_until_complete --> main task
  • L678 main task "async_main_task" (waiting for commands in the queue; running as long as plugin is not stopped)
When the problem happened, I can see that the async_main_task did not end as the last debug instruction on L740 is not happening, but the loop ends as we get into the block starting at L665 (without an exception that happened).
Of course I am not controlling what is happening inside the bimmer_connected library.
F
