LaCrosse sensors not decoded
Posted: Wednesday 16 February 2022 23:24
by Folace93
I have installed 2 LaCrosse sensors, a WSTX145WSDTH (temperature-humidity-anemometer-wind vane) and a WSTX145R (rain gauge), they are not detected by the RFXCOM (on 433 Mhz).
The active protocols in the rfxmanager are Lacrosse and Oregon. The firmware version is 1044.
Does anybody knows if it is planned to implement these sensors in the RfxCom ?
On the other hand, I tested with a RFLink with firmware R49 then R48 without result.
Re: LaCrosse sensors not decoded
Posted: Thursday 17 February 2022 12:07
by JackD
If you live in the Netherlands you could easily sent you hardware to RFXCOM. it will cost you a bit of shippingcosts but the are willing to help.
They did for me. I don't know if they can help without sending the hardware to them. But just contact them and ask them what they can do for you.
I had very good communication with them. Look at there website for contact information
Posted: Thursday 17 February 2022 20:58
by b_weijenberg
Beta firmware 1045 already sent to Folace93
Posted: Thursday 17 February 2022 23:30
by Folace93
Thank's a lot for your responsiveness, I have received the new beta firmware 1045 and flash this new version in the rfxCom, with the RFXflash tool on a PC.
Unfortunately I only get an adjacent LaCrosse sensor (not of mine) but none of the WSTX145.
Domoticz line :
Idx Matériel ID Unit Nom Type Sous-type Données [Niveau du signal RF] [Niveau de batterie] Dernier contact
13 rfxCom 4E00 0 Unknown Temp LaCrosse TX3 16.1 C 6
a small trace obtain with the rfxcom python utility with the same sensor :
./rfxcmd.py -d /dev/ttyUSB0 -l -v
RFXCMD Version 0.3 (739)
Received = 14 01 00 00 02 53 2D 00 08 20 00 03 01 2D 10 5F 46 58 43 4F 4D
Date/Time = 2022-02-17 23:07:05
Packet Length = 14
Packettype = Interface Message
Received = 08 50 05 04 4E 00 00 A1 69
Date/Time = 2022-02-17 23:08:29
Packet Length = 08
Packettype = Temperature sensors
Subtype = La Crosse TX2, TX3, TX4, TX17
Seqnbr = 04
Id = 4E00
Temperature = 16.1 C
Battery = 9
Signal level = 6
the serial of the RFXtrx433XL is DO5OP67D ; the domoticz version is : 2021.1
The rfxcom "sees" the sensors in the "same line" of the LaCrosse ws2652 station in front of it.
(sorry for the language, but I live in France).
Posted: Friday 18 February 2022 8:54
by b_weijenberg
Contact support RFXCOM for help
