Moving Alexa support from HA-bridge to NodeRed (node-red-contrib-virtual-smart-home)
Posted: Thursday 10 February 2022 1:10
Hello
For more flexibility I try to move the Alexa support for my Domoticz
from HA-bridge (on RPi2) to NodeRed (on RPi3B+). On the new RPi3 is running:
Domoticz, Mosquitto as MQTT broker and NodeRed. All are runnig fine and work together.
I have exported and imported the Domoticz configuration from RPi2 to RPi3. So I have
an test environment on the RPi3 but!! without attached Zwave controller and RFXCom.
I see an different behavior:
if press on :8080/#/LightSwitches testlampe -> on I get: Error sending switch command, check device/hardware (idx=724) !
(correct because the RFXCom is not connected) but:
if I say "Alexa switch testlampe on" the bulb symbol :8080/#/LightSwitches changed to on (no hardware error hint).
In NodeRed I see from Domoticz:out :
"Battery" : 255,
"LastUpdate" : "2022-02-09 22:38:36",
"RSSI" : 12,
"description" : "",
"dtype" : "Light/Switch",
"hwid" : "4",
"id" : "00014324",
"idx" : 724,
"name" : "testlampe",
"nvalue" : 1,
"stype" : "Switch",
"svalue1" : "0",
"switchType" : "On/Off",
"unit" : 1
from Alexa I got:
powerState: "ON"
source: "alexa"
directive: "TurnOn"
type: "SWITCH"
rawDirective: object
In a function node in NodeRed I translate name: "testlampe" to IDX and powerState: to "nvalue" and send the
payload via MQTT to Domoticz:in
switch (msg.payload.powerState)
case "ON":
msg.payload = {"idx":724,"nvalue":1,"svalue":"0"};
break;
case "OFF":
msg.payload = {"idx":724,"nvalue":0,"svalue":"0"};
break;
return msg;
As described above: only the bulb symbol changed, no real switch command initated.
My question is: which of the in Domoticz:out recorded values are necessary to send to Domoticz
to initiate a switchcommand and where I can found the values (for the other devices) in Domoticz?
"Battery" : 255,
"RSSI" : 12,
"description" : "",
"hwid" : "4",
"id" : "00014324",
"idx" : 724,
"nvalue" : 1,
"stype" : "Switch",
"svalue1" : "0",
"unit" : 1
from Alexa I got:
powerState: "ON"
source: "alexa"
directive: "TurnOn"
type: "SWITCH"
case "ON":
break;
case "OFF":
break;
return msg;
