Fibaro Rollershutter FGR223 with Somfy Ilmo motor - should this work?
booster
Post by booster »
I'm planning to have electrical shutters installed for the windows at my home.
My current sunscreen is connected to Domoticz via a Fibaro rollershutter, and as I'm happy with that construction, I think I'd like all my shutters also integrated with the zwave fibaro roller shutters (FGR-223)... I don't really see the benefit of going for the tahoma solution and trying to integrate it again in domoticz.
The shop selling/installing the shutters is suggesting the Somy Ilmo motors - they are usually connected to a manual switch (which I will leave out). There is a variant with obstacle protection and without.
My ask: would both Somfy Ilmo models work with the Fibaro Roller Shutter 3 FRG-223?
I would prefer the ones with obstacle protection, but not sure if it might mess up the fibaro? ;)
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
Rinusdevos
Re: Fibaro Rollershutter FGR223 with Somfy Ilmo motor - should this work?
Post by Rinusdevos »
Any chance you discovered it by yourself? I would like to know, if so.
I also want ti use the fgr223 with a somfy motor with wired control. I found some users with troubles using fgr233 with domoticz. It seemed the problem was the possibilities in domoticz. Maybe you can tell me, or someone else, if it is fixed.
