motion sensor at night
Posted: Sunday 06 February 2022 19:26
by fipse
I'd like to accomplish, that the motion sensor only works at night. With this code it works all of the time:
-- LUA trigger set to device
-- Set the time:
now = os.date("%H") * 60 + os.date("%M")
sunrise = timeofday['SunsetInMinutes']
sunset = timeofday['SunriseInMinutes']
if now >= sunset or now <= sunrise then
   	if (devicechanged['PIR2'] == 'On' and otherdevices['Vorne'] == 'Off') then
	commandArray['Vorne']='On FOR 5'
I'm quite a newbe at lua but this should work. I really can't figure out, why it don't. Can someone please point me in the right direction? I'm more the C++ guy :D
73 fipse
Re: motion sensor at night
Posted: Monday 07 February 2022 19:31
by jake
fipse wrote:Hi,
-- Set the time:
73 fipse
I see a something strange:
While defining sunrise and sunset, you mixed them up
When you are new to lua, I'd advise to start with dzvents. Much easier and more consistent in use of several devices.
Posted: Tuesday 08 February 2022 19:50
by fipse
Thanks, that solved it :D
So if someone want exactly this without dzVents:
sunset = timeofday['SunsetInMinutes']
sunrise = timeofday['SunriseInMinutes']
You in the domoticz scripting engine you need to set Trigger: to "Devices"
'PIR2' is the name of the motion sensor. (here via zigbee2mqtt)
'Vorne' is the name of the bulb (also a hue via zigbee2mqtt)
5 ... time in minutes the bulb is set to on
73 de fipse
Posted: Saturday 12 February 2022 12:46
by EddyG
And if someone wants to solve it in dzVents:
local SENSOR = 'PIR2'
local LIGHT = 'Vorne'
        devices = { [ SENSOR ]  = { 'between sunset and sunrise'  } }
    execute = function(dz, item)
        if item.active then
            if not dz.devices(LIGHT).active then
                dz.devices(LIGHT).switchOn().forMin(5)
