DOmoticz crashes and do not restart after adding an equal named virtual device
Mirkoser
Domoticz version: 2021/1
Post by Mirkoser »
Hi All,
i created a script and added a virtual device. Problem, the name of the virtual device is already existing for a "normal device". SO now domoticz crashes and will not restart.
Question, is it possible to remove the virtual device without starting Domoticz. Last backup is 14 days ago...
which file i could edit to remove the virtual device
Bildschirmfoto vom 2022-02-06 12-53-16.png (62.36 KiB) Viewed 918 times
EddyG
Re: DOmoticz crashes and do not restart after adding an equal named virtual device
Post by EddyG »
Yes, it is possible.
Download and install https://sqlitebrowser.org/dl/
Stop Domoticz. Backup the file: Domoticz.db
Copy a copy of Domoticz.db to your Windows environment.
Edit the Domoticz.db table "DeviceStatus" and find your added device and delete that record.
Copy the Database back and start Domoticz.
Mirkoser
Post by Mirkoser »
Yeeesss you saved my a**
Thank you very much. it works
