Put data from counter/sensor into virtual device
Posted: Sunday 06 February 2022 10:24
im a newbie in terms of dvents but i've already created some working srcipts for my energy counters. Now i need a small hint how to transfer data from "real devices" in domoticz into virtual devices in domoticz.
My idea is to modify/filter the data (due to negative values/bad counting) and send the corrected data to the virtual device
For this example i want to show the data of daily usage of my NIBE heatpump . The device 1029 was automatically created by the NIBE heatpump script, so that i cannot change the device anymore.
My script should check every hour the device 1029 and receive the value and transfer it into the new virtual device XXXX
But i have no idea how to do it. But it should be similar to my http request script, correct?
timer = {
'every minute' -- just an example to trigger the request
httpResponses = { 'Wallbox' } -- must match with the callback passed to the openURL command
logging = {
level = domoticz.LOG_INFO,
marker = 'Wallbox_auto',
if (item.isTimer) then
domoticz.openURL({
url = 'http://admin:[email protected]//cnf?cmd=modbus&device=meter2&read=all',
method = 'GET',
callback = 'Wallbox', -- see httpResponses above.
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
local Power = item.json['8062d']
local Energie = item.json['8050q']
domoticz.log(item.json['8062d'] , domoticz.LOG_INFO)
domoticz.log(item.json['8050q'] , domoticz.LOG_INFO)
domoticz.devices('Wallbox').updateElectricity(item.json['8062d'],item.json['8050q'])
