Mosquitto 2.0.12 errors Topic is solved
EddyG
Post by EddyG »
I upgraded mosquitto from 2.0.11 to 2.0.12
With that upgrade came an upgrade of libwebsockets12 to libwebscockets18
After that upgrade I got these errors.
Bad socket read/write on client mqttjs_4cba3646: Invalid arguments provided.
I reverted back to 2.0.11 and libwebsockets12 and everything works fine again.
But does anybody know how to solve the error?
jvdz
Domoticz version: 4.107
Re: Mosquitto 2.0.12 errors
Post by jvdz »
maybe you are seeing this issue and can try that "fix"? : https://github.com/eclipse/mosquitto/is ... -968064107
This seems to be a similar issue like this with another client: https://forum.micropython.org/viewtopic ... 76&p=60836
EddyG
Post by EddyG »
The second link I saw, but no solution.
The first link brought me to the setting "max_keepalive" which was to low in my case.
Tnx. Problem solved.
Eraser
Domoticz version: 3.8153
Post by Eraser »
Thanks for this. I changed "max_keepalive" in Mosquitto from 10 to 1000 and now everything works fine again.
I don't know if this value represents seconds or milliseconds but I guess the latter.
