How do I get DzVents to monitor error status for SolarEdge SE4000H
Posted: Friday 04 February 2022 17:05
by Sjonnie2017
I would like to monitor my SolarEdge SE4000H in case an error occurs.
Since I have the coding skills of a Kangaroo I call upon the more knowledgeable to help me get a working script. I have searched the forum for a comparable issue/solution but was unsuccessful.
If I write the script in human language it would be something like his:
If Solaredge.Vendorstatus = 134 (the error code I would like to monitor)
Then Send email with subject "Error SolarEdge"
I really appreciated some pointers.
Thanks in advance!
Re: How do I get DzVents to monitor error status for SolarEdge SE4000H
Posted: Friday 04 February 2022 17:25
by jvdz
Do you have any connection (Sunspec or something like that ) already working with your SolarEdge?
Posted: Saturday 05 February 2022 7:33
by Sjonnie2017
Tx for your reply. I am using the "modbus TCP" plugin from Addie Janssen. I have a wired connection to my SolarEdge.
Posted: Sunday 06 February 2022 15:20
by Sjonnie2017
I had a (second) look at blockly to see if I could find the device and set it up to send an email if the error code occurs. Not sure if it works though since the error has not occurred again :)
This is what I came up with
Let's hope I never need it :mrgreen:
Posted: Sunday 06 February 2022 15:42
by freijn
Sjonnie, what is the normal status ?
Mine is moving from MQTT ,starting , shutting down.
Pick a status which has a daily change and you can check if your script is working.....
Posted: Sunday 06 February 2022 16:00
by Sjonnie2017
If the error is "resolved" (meaning the Solaredge is back in business) the reported status is "0". Good suggestion to check against this status! I will test this so I know the Blockly works.
