SOLVED - Problem with script dzvents after update
Posted: Friday 04 February 2022 14:46
I created a script to automate the roller shutters of my house
I have a variable 'lastPosDimSal' which I use to store the value of the dimmer.
Two user variables 'var_tpsDec' and 'var_tpsDecDn' which I use to define the rise and fall times of the shutters a 'var_actPosDimSal' which contains the last value of the dimmer before the change of state.
This commands 2 ON/OFF type switches which control an esp-01.
I also put 1% and 99% corresponding to closed and open because otherwise the switches would not go OFF.
Then I created a selector with 6 buttons that allows me to select percentages of opening levels
controlled by a blocky script in 'trigger device' modifying the level of the dimmer. (closed, 25%, 50%, 75%, open, light daylight (13%). It all worked perfectly. But since the last update the script is looping. It automatically resets the last position variable to 99 and never stops.
I admit that I don't understand where the problem comes from, knowing that this is my first attempt at a script.
Any idea that could enlighten me???
Thanks in advance.
Here is an excerpt from the Domoticz log:
active = true,
devices = {'dimmer_salon'},
data = {lastPosDimSal = { initial = 99 } },
execute = function(domoticz, dimmer_salon)
--local var_lastPosDimSal = domoticz.variables('var_lastPosDimSal')
local var_actPosDimSal = domoticz.variables('var_actPosDimSal')
local var_tpsDec = domoticz.variables('var_tpsDec')
local var_tpsDecUp = domoticz.variables('var_tpsDecUp')
-- On affiche le niveau et l'état du dimmer
domoticz.log('dimmer_salon level is')
domoticz.log(dimmer_salon.level)
domoticz.log('état dimmer salon')
domoticz.log(dimmer_salon.state)
-- On défini les variables
var_actPosDimSal.set(dimmer_salon.level)
lastPosDimSal=var_actPosDimSal.value
domoticz.log('la valeur précédente était :')
domoticz.log(lastPosDimSal)
local fermsal = domoticz.devices('fermeture_salon')
local ouvsal = domoticz.devices('ouverture_salon')
-- test modif
if (dimmer_salon.state == 'Open') then
dimmer_salon.dimTo(99)
if (dimmer_salon.state == 'Closed') then
dimmer_salon.dimTo(1)
-- fin test
-- condition d'ouverture
if (dimmer_salon.level < lastPosDimSal) then
tpsDecDn = (lastPosDimSal - dimmer_salon.level) * var_tpsDec.value
-- on ferme immédiatement le switch ouverture
ouvsal.switchOff()
-- end
fermsal.switchOn().forSec(tpsDecDn)
domoticz.log('la valeur est inférieure')
domoticz.log('le temps de fermeture est de')
domoticz.log(tpsDecDn)
-- on réinitialise la variable à 0
tpsDecDn = (0)
-- condition de fermeture
if (dimmer_salon.level > lastPosDimSal) then
tpsDecUp = (dimmer_salon.level - lastPosDimSal) * var_tpsDecUp.value
--o n ferme immédiatement le switch fermeture
fermsal.switchOff()
-- end
ouvsal.switchOn().forSec(tpsDecUp)
domoticz.log('la valeur est supérieure')
domoticz.log('le temps d ouverture est de')
domoticz.log(tpsDecUp)
tpsDecUp = (0)
Thanks in advance.
2022-02-04 09:01:02.928 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:02.109 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.109 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.110 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.110 Status: dzVents: Info: 99
2022-02-04 09:01:02.110 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.110 Status: dzVents: Info: Open
2022-02-04 09:01:02.110 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.111 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.112 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.152 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:02.284 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.284 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.285 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.285 Status: dzVents: Info: 99
2022-02-04 09:01:02.285 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.285 Status: dzVents: Info: Open
2022-02-04 09:01:02.285 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.287 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.287 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.291 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:02.422 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.422 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.423 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.423 Status: dzVents: Info: 99
2022-02-04 09:01:02.423 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.423 Status: dzVents: Info: Open
2022-02-04 09:01:02.423 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.424 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.425 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.429 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:02.562 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.562 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.563 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.563 Status: dzVents: Info: 99
2022-02-04 09:01:02.563 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.563 Status: dzVents: Info: Open
2022-02-04 09:01:02.563 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.565 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.565 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.567 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:02.734 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.734 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.736 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.736 Status: dzVents: Info: 99
2022-02-04 09:01:02.736 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.736 Status: dzVents: Info: Open
2022-02-04 09:01:02.736 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.738 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.739 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.744 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:02.878 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:02.878 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:02.879 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:02.879 Status: dzVents: Info: 99
2022-02-04 09:01:02.879 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:02.879 Status: dzVents: Info: Open
2022-02-04 09:01:02.879 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:02.883 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:02.884 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:02.923 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:03.065 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:03.242 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:03.053 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:03.053 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:03.054 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:03.054 Status: dzVents: Info: 99
2022-02-04 09:01:03.054 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:03.054 Status: dzVents: Info: Open
2022-02-04 09:01:03.054 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:03.056 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:03.057 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:03.060 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:03.193 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:03.193 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:03.194 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:03.194 Status: dzVents: Info: 99
2022-02-04 09:01:03.194 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:03.194 Status: dzVents: Info: Open
2022-02-04 09:01:03.194 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:03.195 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:03.197 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:03.197 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:04.025 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.160 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.338 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.516 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.652 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.830 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:04.968 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.103 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.282 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.461 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.598 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.775 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:05.912 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.090 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.227 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.407 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.544 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.683 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.862 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:06.855 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:06.996 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:06.996 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:06.997 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:06.997 Status: dzVents: Info: 99
2022-02-04 09:01:06.997 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:06.997 Status: dzVents: Info: Open
2022-02-04 09:01:06.997 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:06.999 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.044 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.183 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.321 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.458 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.593 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.780 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.958 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:07.000 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.039 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.169 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.170 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.170 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.171 Status: dzVents: Info: 99
2022-02-04 09:01:07.171 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.171 Status: dzVents: Info: Open
2022-02-04 09:01:07.171 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.172 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.173 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.176 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.308 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.308 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.309 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.309 Status: dzVents: Info: 99
2022-02-04 09:01:07.309 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.309 Status: dzVents: Info: Open
2022-02-04 09:01:07.309 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.311 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.312 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.316 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.445 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.445 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.446 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.446 Status: dzVents: Info: 99
2022-02-04 09:01:07.446 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.446 Status: dzVents: Info: Open
2022-02-04 09:01:07.446 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.448 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.449 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.452 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.583 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.583 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.584 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.584 Status: dzVents: Info: 99
2022-02-04 09:01:07.584 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.584 Status: dzVents: Info: Open
2022-02-04 09:01:07.584 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.585 Status: dzVents: Info: 99
2022-02-04 09:01:07.586 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.587 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.589 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.757 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.757 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.758 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.758 Status: dzVents: Info: 99
2022-02-04 09:01:07.758 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.758 Status: dzVents: Info: Open
2022-02-04 09:01:07.758 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.760 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.761 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:07.774 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.905 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:07.905 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:07.906 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:07.906 Status: dzVents: Info: 99
2022-02-04 09:01:07.906 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:07.906 Status: dzVents: Info: Open
2022-02-04 09:01:07.906 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:07.909 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:07.910 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:07.911 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:08.063 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:08.201 volets_salon: Light/Switch (dimmer_salon)
2022-02-04 09:01:08.050 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:08.050 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:08.051 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:08.051 Status: dzVents: Info: 99
2022-02-04 09:01:08.051 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:08.051 Status: dzVents: Info: Open
2022-02-04 09:01:08.051 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:08.053 Status: dzVents: Info: ------ Finished dimmer_salon_ok
2022-02-04 09:01:08.054 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2022-02-04 09:01:08.057 Status: Set UserVariable var_actPosDimSal = 99
2022-02-04 09:01:08.188 Status: dzVents: Info: Handling events for: "dimmer_salon", value: "Open"
2022-02-04 09:01:08.188 Status: dzVents: Info: ------ Start internal script: dimmer_salon_ok: Device: "dimmer_salon (volets_salon)", Index: 288
2022-02-04 09:01:08.189 Status: dzVents: Info: dimmer_salon level is
2022-02-04 09:01:08.189 Status: dzVents: Info: 99
2022-02-04 09:01:08.190 Status: dzVents: Info: état dimmer salon
2022-02-04 09:01:08.190 Status: dzVents: Info: Open
2022-02-04 09:01:08.190 Status: dzVents: Info: la valeur précédente était :
2022-02-04 09:01:08.190 Status: dzVents: Info: 99
2022-02-04 09:01:08.191 Status: dzVents: Info: ------ Finished dimmer_salon_ok
