Domoticz - data download via JSON
Posted: Thursday 03 February 2022 18:21
Hello. First I would like to apologize for my English, but I use Google translator
I have an air purity sensor from which I would like to have readings in Domoticz.
I read the data from the sensor after entering http: // SENSOR_IP_ADDRESS / data.json and receive the data in this format:
How to write a script to extract, for example, data to the "humi_AIR" switch with IDX: 123 from the {"value_type" section: "BME280_humidity", "value": "93.70"}?
{"software_version": "NAMF-2020-43", "age":"104", "measurements":"868", "uptime":"146292", "sensordatavalues":[{"value_type":"SDS_P1","value":"33.50"},{"value_type":"SDS_P2","value":"17.50"},{"value_type":"HECA_temperature","value":"5.39"},{"value_type":"HECA_humidity","value":"90.06"},{"value_type":"HECA_Tdc","value":"0.00"},{"value_type":"HECA_RHdc","value":"100.00"},{"value_type":"HECA_dc","value":"100.00"},{"value_type":"BME280_temperature","value":"3.44"},{"value_type":"BME280_pressure","value":"99522.66"},{"value_type":"BME280_humidity","value":"92.49"},{"value_type":"samples","value":"105264"},{"value_type":"min_micro","value":"1290"},{"value_type":"max_micro","value":"138996"},{"value_type":"signal","value":"-80"}]}
