Automatic Updates: Possible?
RubenOrtizD25
Post by RubenOrtizD25 »
I have a system in place with a Raspberry Pi that triggers an RFXCOM card to manage my blinds. The issue I have is that every time there is an update in Domoticz it stops working. In order for it to work again I have to login to the raspberry pi and run a "sudo ./updaterelease" manually.
Is there a way to have Domoticz updates installed automatically?
Many thanks in advance.
Best,
Ruben
Re: Automatic Updates: Possible?
Short term solution would be to switch off the automatic update check so you will have to do that manually and on your time schedule.
Can be done through menu Setup - Settings
RubenOrtizD25
Thanks, but where exactly? When I go to Setup-Settings I do not see "Disable Updates"; could you please precise?
MAny thanks in advance.
HansOtten
Domoticz version: 2021-1
Post by HansOtten »
Setup - Settings - middle right column -Check for software updates
And Apply settings
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
RubenOrtizD25
Hello again,
Thanks. Issue solved!
