Fibaro Dimmer 2 - Standard Domoticz Timer for Dimmer turns on and immediatly off (z-stick GEN5)
Posted: Sunday 30 January 2022 13:40
I've fitted a Fibaro Dimmer 2 and it works fine when I use the Domoticz application and turn the swith manually and also when I physically change the switch. I've set a couple of timers, the once that turn 'off' the device seem to work but the ones that need to turn on the device trigger both an 'On' and 'Off' event.
The following timer is set within the standard Domoticz UI for this 'dimmer' Switch:
Turn on the lights 'On Time': 06:15
What happens is:
end-result: Lights haven't been turned on.
I've tried doing this on my Synology Domoticz installation first but as Jadahl is no longer creating packages I decided that I needed to upgrade my Domoticz installation to a recent version as that might resolve my issue. So I did, installed a raspberry Pi with domoticz instead and I'm not doing this on Domoticz Stable: 2021.1.
Unfortunatly I get sort of the same end-result, my dimmer gets triggered at the time I want and it tries to turn on my device but the 'Z-Stick GEN5' user then also invokes an 'off' command.
I've never experienced this kind of behaviour before and I'm a bit puzzled now as I think I ruled out that this is caused by the Domoticz installation/version. The only thing I'm not sure of that can cause this is:
- Distance, can it be that the Fibaro Dimmer 2 Switch wasn't 'reachable' and therefore my timer didn't work and my 'z-stick' ensured that the status of the switch remained correct: Off (this would be strange as I'm able to turn it on manually via 'Domoticz UI')
Ps. I tried setting the dimmer 'on time' via blockly as well, sort of the same result:
Has anyone else experienced such behavior and or has any suggestion on what to look for?
Thanks for all the help and inputs. It's really very much appreciated.
Kind regards,
Tim
What happens is:
Date Data User
2022-01-30 06:15:01 Off Z-Stick GEN5
2022-01-30 06:15:01 On Z-Stick GEN5
2022-01-30 06:15:01 Set Level: 100 % timerI've tried doing this on my Synology Domoticz installation first but as Jadahl is no longer creating packages I decided that I needed to upgrade my Domoticz installation to a recent version as that might resolve my issue. So I did, installed a raspberry Pi with domoticz instead and I'm not doing this on Domoticz Stable: 2021.1.
Date Data User
2022-01-30 13:54:01 Off Z-Stick GEN5
2022-01-30 13:54:01 Set Level: 61 % Z-Stick GEN5
2022-01-30 13:54:00 On EventSystem/Turn on Tuinverlichting via Blockly_1Thanks for all the help and inputs. It's really very much appreciated.
Kind regards,
Tim
