How is it possible to have TWO different representations of the same block?
Posted: Friday 28 January 2022 9:51
by lastofthejediknights
I have a custom layout, where I am using the dial representation of several blocks, including a thermostat.
This all looks nice, however getting a easy / decent small change to the setpoint on an iPad mounted to a wall, isn't easy.
How might I be able to show the "standard" representation, with it's up/down buttons on the same page, ideally just below the "Dial", or is there another method of creating some UP/DOWN buttons to change the value?
Many thanks
Re: How is it possible to have TWO different representations of the same block?
Posted: Friday 28 January 2022 11:09
by Lokonli
If you remove "type: 'dial'" from the block definition you will get a normal block. It will look like this:
- thermostat.jpg (7.22 KiB) Viewed 6821 times
That is the only existing alternative representation at the moment.
What I could add relatively easy is an up-down dial for thermostats comparable to the blinds dial:
- dialblinds.jpg (14.49 KiB) Viewed 6821 times
Would that work?
Posted: Friday 28 January 2022 17:33
Oh, Yes that would be great, just what I would ideally want.
I understand the "normal" non dial type, and am using it for several items, but the thermostat dial, with effectively up and down buttons, would be great.
Many Thanks
Nigel
Posted: Friday 18 February 2022 9:58
Thankyou for the 3.9 update.
Does this enable a solution as you mention above regarding the Blinds type dial?
If so could you possibly show a config example for a thermostat?
Regards Nigel
Posted: Friday 18 February 2022 13:43
by Lokonli
lastofthejediknights wrote: Friday 18 February 2022 9:58
Regards Nigel
No, not yet.
Posted: Friday 18 February 2022 14:29
Many Thanks
