unknown sensor in Domoticz log
Posted: Tuesday 25 January 2022 15:30
Can anyone tell me where the "Pomp_2" , "DeurSensor_1&2" can be found?
These sensors are not present in the current configuration and also there is no sensor triggered at that time
2 weeks ago I had a crash where there was no more communication between devices and Zigbee2mqtt and a had to rebuild from scratch.
I restored the old Domoticz database and had to re-pair all the devices again to get them working again.
2022-01-25 15:14:03.266 Nefit Easy: Temp (Nefit Room Temp)
2022-01-25 15:14:03.464 Nefit Easy: Temp (Nefit Flow Temp)
2022-01-25 15:14:08.646 Pi: General/Percentage (HDD /)
2022-01-25 15:14:08.650 Pi: General/Percentage (HDD /boot)
2022-01-25 15:14:15.038 EventSystem: Event triggered: Pomp_2
2022-01-25 15:14:17.382 Dummy: Light/Switch (Test)
2022-01-25 15:14:17.386 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:17.376 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:18.660 Pi: General/Percentage (Pi CPU)
2022-01-25 15:14:18.689 Pi: General/Custom Sensor (Arm Clock Speed)
2022-01-25 15:14:18.721 Pi: General/Custom Sensor (V3D Clock Speed)
2022-01-25 15:14:18.737 Pi: General/Custom Sensor (Core Clock Speed)
2022-01-25 15:14:18.741 Pi: General/Percentage (Pi Mem)
2022-01-25 15:14:18.743 Pi: General/Custom Sensor (Process Usage)
2022-01-25 15:14:19.271 Dummy: Light/Switch (Test)
2022-01-25 15:14:19.277 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:19.265 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:21.566 Dummy: Light/Switch (Test)
2022-01-25 15:14:21.570 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:21.561 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:22.286 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.290 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:22.687 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.689 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:22.896 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.898 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:22.281 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:22.685 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:22.894 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:23.076 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.078 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:23.225 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.226 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:23.588 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.592 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:23.876 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.880 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:23.073 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:23.222 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:23.584 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:23.871 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:24.059 Dummy: Light/Switch (Test)
2022-01-25 15:14:24.063 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:24.173 Dummy: Light/Switch (Test)
2022-01-25 15:14:24.177 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:24.055 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:24.168 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:27.420 Dummy: Light/Switch (Test)
2022-01-25 15:14:27.425 EventSystem: Event triggered: DeurSensor_2
