Topics log show in line format
Posted: Monday 17 January 2022 8:32
by Creo2005
Hi.
For a while I noticed that in the log is:
2022-01-17 09:25:17.986 CC2652P: 30 84 01 00 1e 7a 69 67 62 65 65 32 6d 71 74 74 2f 30 78 30 0Į..zigbee2mqtt/0x0
2022-01-17 09:25:17.986 CC2652P: 30 31 35 38 64 30 30 30 31 61 34 62 35 65 35 7b 22 62 61 74 0158d0001a4b5e5{"bat
2022-01-17 09:25:17.986 CC2652P: 74 65 72 79 22 3a 31 30 30 2c 22 68 75 6d 69 64 69 74 79 22 tery":100,"humidity"
2022-01-17 09:25:17.986 CC2652P: 3a 33 34 2e 30 32 2c 22 6c 69 6e 6b 71 75 61 6c 69 74 79 22 :34.02,"linkquality"
2022-01-17 09:25:17.986 CC2652P: 3a 31 30 32 2c 22 70 72 65 73 73 75 72 65 22 3a 39 38 37 2c :102,"pressure":987,
2022-01-17 09:25:17.986 CC2652P: 22 74 65 6d 70 65 72 61 74 75 72 65 22 3a 32 31 2e 39 34 2c "temperature":21.94,
2022-01-17 09:25:17.986 CC2652P: 22 76 6f 6c 74 61 67 65 22 3a 33 30 34 35 7d .. .. .. .. .. "voltage":3045}
When it was like that:
zigbee2mqtt/0x00158d0001a4b5e5{"battery":100,"humidity":34.02,"linkquality":102,"pressure":987,"temperature":21.94,"voltage":3045}
How to return the old view?
Re: Topics log show in line format
Posted: Monday 17 January 2022 10:18
by EddyG
With what are you viewing the log file? And what program/adaptor are you using?
It is strange that the data it self is exactly the same?
Posted: Monday 17 January 2022 10:36
by Creo2005
EddyG wrote: Monday 17 January 2022 10:18 With what are you viewing the log file? And what program/adaptor are you using?
This log in Domoticz web gui.
Posted: Monday 17 January 2022 11:13
by EddyG
Did you change loglevel and/or debuglevel on the commandline?
Posted: Monday 17 January 2022 11:27
by Creo2005
EddyG wrote: Monday 17 January 2022 11:13 Did you change loglevel and/or debuglevel on the commandline?
Yes of cose, in MQTT device, but i can't get the result
Posted: Monday 17 January 2022 13:04
by EddyG
You were writing about the Domoticz logging, so did you change the logging level of Domoticz on the command line of Domoticz?
Or else where did you change anything in regard to logging?
Posted: Monday 17 January 2022 13:11
by Creo2005
EddyG wrote: Monday 17 January 2022 13:04 You were writing about the Domoticz logging, so did you change the logging level of Domoticz on the command line of Domoticz?
How to do it through command line of Domoticz?
Posted: Monday 17 January 2022 13:31
by EddyG
Just do a 'domoticz -help' and you see all the command line options.
Those can be changed in the startup script.
As you know nothing about the command line option, it is logical that you did not change those.
What did you mean by "Yes of cose, in MQTT device, but i can't get the result"
Posted: Monday 17 January 2022 15:09
by Creo2005
EddyG wrote: Monday 17 January 2022 13:31 Just do a 'domoticz -help' and you see all the command line options.
In Domoticz Hardware I change the type of log (sorry, "MQTT" - i messed up):
- Coordinator - Debug: Verbose
(see in log: Zigbee2mqtt log level is debug) and take: @CC2652P: 30 84 01 00 1e 7a 69 67 62 65 65 32 6d 71 74 74 2f 30 78 30 0Į..zigbee2mqtt/0x0 ......"
if Debug: True -> Debug logging mask set to: PYTHON
Posted: Tuesday 18 January 2022 10:40
by EddyG
Make your self a little bit clearer, it looks to me that you mess up all kind of statements.
You write about Hardware, devices, coordinator, debug, zigbee2mqtt, logging mask, Python.
State clearly what you have and where you are talking about.
From an early post I made up that the Domoticz.log is 'screwed-up'
That is probably due to a changed debug setting.
