Howto, simple temperature that switch on / off device?
BarryT
Domoticz version: 2024.3
Post by BarryT »
can someone tell me a how to simple turn on or off a device by temperature?
if (devicechanged['Temperatuur Buiten'] ~= nil then print("Temperatuur Buiten: " .. devicechanged['Temperatuur Buiten'] .. " WarmtepompBoiler:" .. otherdevices['WarmtepompBoiler'])
if (devicechanged['Temperatuur Buiten'] > 6 and otherdevices['WarmtepompBoiler'] == 'Off') then print("Buitentemperatuur boven 6 graden dus Boiler AAN na 5 minuten..") commandArray['WarmtepompBoiler'] == 'On'
elseif (devicechanged['Temperatuur Buiten'] < 6 and otherdevices['WarmtepompBoiler'] == 'On') then print("Buitentemperatuur onder 6 graden dus Boiler UIT..") commandArray['WarmtepompBoiler'] == 'Off'
does not work :(
psubiaco
Re: Howto, simple temperature that switch on / off device?
Post by psubiaco »
you have used == (comparison) instead of = (assignment) !!
You have to write commandArray["outputdevice"]="On"
Good luck
Paolo
