can't access python requests module
Posted: Tuesday 11 January 2022 16:23
by AMelbye
Hi, I'll start with sofware versions:
Version: 2021.1
Build Hash: 8547c5b7e
Compile Date: 2021-04-17 17:29:11
dzVents Version: 3.1.7
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
I'm on a raspberry pi running no GUI-version of (I think the the latest) raspbian
I'm making a script where I want to use the requests module to call an API.
However I can not get the module to load. I've now simplified down to this:
"#!/usr/lib/python3/dist-packages/" #I found advice in another thread about adding the path like this - did not work.
import requests
I get the error:
2022-01-11 16:19:00.185 Error: EventSystem: Failed to execute python event script "/home/pi/domoticz/scripts/python/script_time_sjekknoe.py"
2022-01-11 16:19:00.186 Error: EventSystem: Traceback (most recent call last):
2022-01-11 16:19:00.186 Error: EventSystem: File "/home/pi/domoticz/scripts/python/script_time_sjekknoe.py", line 2, in <module>
2022-01-11 16:19:00.186 Error: EventSystem: import requests
2022-01-11 16:19:00.186 Error: EventSystem: ModuleNotFoundError: No module named 'requests'
How to I tell domoticz to look for the module in the right place? It works fine when I run python in the console.
I've tried adding it with sys, but that doesn't seem to work either
Re: can't access python requests module
Posted: Tuesday 11 January 2022 22:21
Try to install the request module with sudo as Domoticz will probably run as root.
There is currently a big issue with python plugins on bullseye. It is sidenote: known and a fix is close but until that there is no other way than wait, downgrade to Buster or use a docker environment.
Posted: Wednesday 12 January 2022 0:51
by AMelbye
@waltervl Thanks for your reply!
I actually just figured it out, I must have misspelled something the first time around. I wrote this code for my script and this problem is now solved:
import DomoticzEvents as DE
import sys
if '/usr/lib/python3/dist-packages/' not in sys.path :
DE.Log('Path not found')
sys.path.append('/usr/lib/python3/dist-packages/')
DE.Log('Path added')
else:
DE.Log('Path found')
import requests
Thanks for your reply though. I don't intend to use any plugins for now, I'm however working on a script to adjust my heaters based on electricity price, and I'm using python this time because I used it more recently and coding with it would be quite effortless if I didn't have to struggle with the implementation. My next problem is that writing to user variables doesn't seem to work... I might be able to do without it though as long as changing state of devices still works (I haven't checked)
Posted: Tuesday 11 April 2023 21:53
by PeJeWe
waltervl wrote: Tuesday 11 January 2022 22:21
Is there a fix on bullseye for this now, because i have the same problem with a import requests on a python script
Posted: Wednesday 12 April 2023 9:48
That is all fixed in 2022.2 and later.
There are still some issues when you define sub functions in your python script, see for example
viewtopic.php?p=297430
Posted: Wednesday 12 April 2023 20:14
by PeJeWe
waltervl wrote: Wednesday 12 April 2023 9:48
i want to use a python script for my toon because when i let it run by DzVents i get random errors like "Toon has been running for more then 10 seconds".
So i want to use the following python script:
import json
import os
import requests
ToonThermostat = 'Toon Thermostaat'
ToonTemperature = 'Temp Woonkamer'
ToonIP = '192.168.100.130'
DomoticzIP = '192.168.100.140:8080'
def update_temperatures():
url = "http://{ToonIP}/happ_thermstat?action=getThermostatInfo"
response = requests.get(url)
if response.status_code == 200:
thermostat_info = json.loads(response.content)
current_setpoint = thermostat_info['currentSetpoint'] / 100
current_temperature = thermostat_info['currentTemp'] / 100
current_temperature = round(current_temperature, 1)
if round(domoticz.devices(ToonThermostat).setPoint * 100) != round(current_setpoint * 100):
domoticz.log('Update van de temperatuur instelling naar: ' + str(current_setpoint) + ' °C', domoticz.LOG_FORCE)
domoticz.devices(ToonThermostat).updateSetPoint(current_setpoint)
if round(domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1)) != round(current_temperature, 1):
domoticz.log('Update van de Kamertemparatuur : ' + str(current_temperature) + ' °C', domoticz.LOG_FORCE)
domoticz.devices(ToonTemperature).updateTemperature(current_temperature)
def execute(domoticz):
if debug:
domoticz.log('DEBUG: Script uitvoeren', domoticz.LOG_INFO)
'on': {'timer': {'every minute'}},
'logging': {'level': domoticz.LOG_ERROR, 'marker': 'scriptVar'},
'execute': execute
i have set the trigger to all
when i run this in domoticz in events ill get the following error:
File "ToonPY", line 3, in <module>
Error: ModuleNotFoundError: No module named 'requests'
I run this on my rpi3b+ with bullseye
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (2.28.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests) (3.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests) (1.26.15)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests) (2022.12.7)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests) (3.1.0)
Posted: Wednesday 12 April 2023 23:43
Seems the same issue as discussed in the other topic I referred to.
Your Dzvents issue is probably easier to solve. Did you use the async way of calling openUrl()?
Posted: Thursday 13 April 2023 6:38
by PeJeWe
waltervl wrote: Wednesday 12 April 2023 23:43
My coding skills are not that good to fully understand what you mean by "the async way of calling openUrl()"
Posted: Thursday 13 April 2023 20:37
It is discussed in the Dzvents documentation:
https://www.domoticz.com/wiki/DzVents:_ ... P_requests
The use of callback will make that a slow http connection will not stall your scripts.
