Fgt001 parameters
Posted: Tuesday 11 January 2022 11:50
by rfvdboom
I have a fibaro radiator device. After some reading in the forum i fixed the problems with setpoint etc. What i am not getting fixed, is editing the parameters. It is always on 1. When is change is to any other number, is gets back to 1. How do you edit this parameters? On my other zwave devices i dont have this problem.
I am running the latest stable domoticz version.
Thx. Grtz
Re: Fgt001 parameters
Posted: Sunday 16 January 2022 10:28
by Busmeikel
same problem with the parameters.
Could you please send me your solution with the setpoint? Got one with the firmware 4.7 and cannot set the heater remotely with Domoticz (Version: 2021.1 (build 14058)).
Thanx
Meikel
Posted: Sunday 16 January 2022 15:46
by rfvdboom
U have to set the setpoint in correct temperature and then give commando for "heat".
Yourdomoticzip/json.htm?type=setused&idx=(IDX OF THERMOSTATE MODE)&description=&tmode=(0,1, or 2)&protected=false&used=true
Tmode:
0=off
1=heat
2=full open
Editing parameters is control panel of zwave suddenly worked for me to change setting.
Posted: Thursday 20 January 2022 15:27
by Busmeikel
Sorry,
I don't understand your answer, I'm not used in Json-Stuff.
I cannot control the valve via Domoticz. When I change the temperature directly at the valve it works and I can see the new setting in Domotics, so it is properly included.
What do I have to do to control the valve remotely?
Posted: Friday 21 January 2022 6:49
by Busmeikel
Today I can control it suddenly via Domoticz, but no feedback in "Utilities" -> Set point.
Strange...
