Linkind door window sensor Zigate plugin issue
Posted: Monday 10 January 2022 21:55
I recently upgraded the Zigate firmware to 0321 and took the plunge to the new OPDM version so had to re-pair all my devices which has (mostly) gone smoothly.
I upgraded to the latest Zigate plugin at same time 6.0.001
My Linkind Door and Window sensors would re-register when I re-did the pairing on the device however the open/close status would not update.
So I deleted the device from Domoticz and did a re-pair and the log is included below. The device is created in Domoticz but it fails to update with open/close status.
Not sure if this is a Zigate firmware issue or if it is when I updated the Plugin (it was working fine on ~5.17)
2022-01-10 20:46:48.394 Status: Zigate: (Zigate) Request Accepting new Hardware for ever
2022-01-10 20:46:48.609 Status: Zigate: (Zigate) Accepting new Hardware: Enable (On)
2022-01-10 20:46:57.275 Status: Zigate: (Zigate) [None] NEW OBJECT: ee93 None
2022-01-10 20:46:58.200 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Active Endpoint Response Ep: 01 LQI: 93
2022-01-10 20:46:58.201 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Request Simple Descriptor for Ep: 01
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Simple Descriptor Response EP: 0x01 LQI: 96
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 ProfileID 0104
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 ZDeviceID 0402
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Application Version 0000
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster IN Count: 06
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 1: 0000 (Basic)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 2: 0001 (Power Configuration)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 3: 0003 (Identify)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 4: 0020 (Poll Control)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 5: 0500 (IAS Zone)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 6: 0b05 (Diagnostics)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster OUT Count: 01
2022-01-10 20:46:58.727 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-01-10 20:46:59.116 Status: Zigate: (Zigate) [None] NEW OBJECT: ee93 Request Node Descriptor
2022-01-10 20:47:04.072 Status: Zigate: (Zigate) [1] NEW OBJECT: ee93 Model Name: ZB-DoorSensor-D0003
2022-01-10 20:47:09.067 Status: Zigate: (Zigate) [2] NEW OBJECT: ee93 Model Name: ZB-DoorSensor-D0003
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) 'onHeartbeat' failed 'KeyError'.
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 1390 in '/home/john/domoticz/plugins/Domoticz-Zigate/plugin.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 877 in '/home/john/domoticz/plugins/Domoticz-Zigate/plugin.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 784 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 103 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 354 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 396 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 416 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 515 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
