Webinterface not available after Tradfri hardware installed
Posted: Monday 03 January 2022 21:21
by Ketting
Hi all!
I did a clean install of Domoticz on a Pi4 and installed the Moroen Plugin (https://github.com/moroen/IKEA-Tradfri-plugin.git IKEA-Tradfri)
to control my Tradfri stuff.
In the test (python3 plugin.py list ) I see all the bulbs and switches.
But from the moment I create the hardware in Domoticz I cannot access Domoticz anymore.
The status is active, but when I try to enter the webinterface I get the offline page.
Is there anyone who has had this before?
Regards,
Niels
Re: Webinterface not available after Tradfri hardware installed
Posted: Monday 31 January 2022 18:34
by ddum
I seem to have the problem too. I have other plugins installed (Tuya) that don't seem to have any problem.
When installing the IKEA Tradfri plugin using the "PI" install steps in https://github.com/moroen/IKEA-Tradfri- ... /README.md
- I add the IKEA-Tradfri plugin through the "Hardware" tab
- restart Domoticz
- refresh the web interface -> Offline
- run "sudo /etc/init.d/domoticz.sh status" in command line -> Active: active (exited)
Remove the IKEA-Tradfri directory and restarting Domoticz allows things to function again.
I had the plugin working on a previous version of Raspberry pi and Raspbian so I'm suspecting either that the python version is different or that it has to do with a permissions problem that I can't figure out.
Here is the version that is running (just updated to latest stable, but had the problem under 2021.2 also):
Version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 09:34:32
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Posted: Monday 14 February 2022 16:44
by DuDo
no resolve?
Posted: Monday 14 February 2022 17:17
by waltervl
If you are on a RPi with Bullseye OS it is a known issue that a lot of Python plugins are failing at the moment.
Alternatives to solve this are:
1. Build domoticz yourself on your Pi, it will work. https://www.domoticz.com/wiki/Build_Dom ... rom_source
2. Use a Docker build https://www.domoticz.com/wiki/Docker
3. Downgrade your OS to Raspberry Pi OS (Legacy) (32b) https://www.raspberrypi.com/software/operating-systems/
Posted: Monday 14 February 2022 19:14
by shyamk
I've just intalled some tradfri lamps at home. Everything is up and running, and with the mobile phone everything is ok.
192.168.0.1 router login 192.168.l.l
now I was trying to connect via browser to the gateway, but I don't know the login/password to enter the airOS page.
I've tried ubnt/ubnt and the blank/blank but both are not good. Could someone help me? pls
