OWL CM160 : New batteries on Sensor, how to correct values ?
Posted: Tuesday 21 December 2021 17:36
by Jeremob
Hello guys,
I'm using couter powermeter OWL CM160 since few years, working well
But Today, I decide to change batteries, too low
Not a big deal to do that, and to replace old device by the new detected device, to merge datas ...
But the problem is : the CM160 with new batteries transmit a value from 0, incremented by the consumed power
The old device has incremented is value up to 15.000kwh when the new device start from 0 ...
So, the data merge is impossible as you can see in screenshot
For the moment I have old device, and new device
So, 2 questions are there :
I cannot remove the wrong value "-15.575" (shift + clic) from the old device, nothing happen ...
- Is there a way to remove this wrong value ?
When its done, is this possible to have a workaround to merge data correctly with the new device who started from 0 ?
Or the only way is to have old (for history) and new device ?
Thanks a lot guys !
