Snooze timer event
Posted: Sunday 19 December 2021 23:23
I have created a group called "All OFF"
When this group is activated, all of my lights will turn of in a specific sequence and interval.
For example, all outdoor lights are switched off immediately, living room 2 minutes later, and hallway stays on for 2 minutes, so i can find the door and walk the stairs safely to bed
Currently I'm using a Klikaan-Klikuit smart wall socket (ZCC-3500) to switch on/off my livingroom light.
On top of this switch ther is a small switch to manually switch it on or off.
What I want to do is, when the timer of the group "All Off", wich is activated every night at 23:30, is activaded, the livingroomlight turns off immediately.
If I do nothing, the sequence will continue to kill all the lights, BUT, when I manually switch on the livingroomlight, using the KaKu switch, I would like to snooze the timer function with, let's say 15 or 30 minutes.
So, is it possible to intterupt this sequence and trigger it again after 30 minutes when i pressed the KaKu button.
