NooB question: how to send URl when switch is pressed?
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
I have a probably simple question about sending a URL when a button is pressed. I have read the documentation but I am afraid programming is not my forte and I can't make heads or tails of it. But I do need this so I can fully use my Shelly 2.5 switches (roller shutter mode) with my Zigbee 2-gang switches.
So I hope you will be able to help me.
I have a dzVents script that triggers my roller shutter on the press of a button. This used to work flawlessly with my Zigbee roller shutter device. I have replaced the Zigbee roller shutter device with a Shelly 2.5. The plugin does not support the "stop" command but I have found out I can send a URL request that stops the roller shutter.
Now I am struggling to get the dzVents script to send the url.
The URL looks like this:
http://192.168.xxx.yyy/roller/0?go=stop
The original dzVents script looks like his:
--Control Zigbee roller shutter module QS-ZIGBEE-C01 with additional switch (Aqara WXKG07LM)
return
    on =
        devices =
            'Schakelaar Keuken 2',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'roomSwitcher',
    execute = function(dz, item)
        if item.state == '10' or item.state == 'B1' then
            dz.devices(396).open()
        elseif item.state == '20' or item.state == 'B2' then
            dz.devices(396).close()
        elseif item.state == '30' or item.state == 'B3'then
            dz.devices(396).stop()
--            domoticz.openURL('http://192.168.xxx.yyy/roller/0?go=stop')
        dz.log(item.state, dz.LOG_DEBUG)
I tried to send the URL as you can see in the comment line. But if I uncomment that line (and comment the line above it) it does not work.
What do I need to change?
Thanks in advance!
YouLess Energy meter
keros
Re: NooB question: how to send URl when switch is pressed?
Post by keros »
The line doesn't work but you should have some info in the DomoticZ logs.
In your case, you have definied execute = function(dz, item) and use it dz.devices(396).open() or dz.log(item.state, dz.LOG_DEBUG). That is why domoticz.openURL('http://192.168.xxx.yyy/roller/0?go=stop') is not recognized.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Sjonnie2017
Thanks for your reply.
I found this in the log after I pressed the button(s) on the switch:
2021-12-20 18:39:44.013 ConBee2: (ConBee2) ### Update device (Schakelaar Keuken 2) : {'nValue': 30, 'sValue': '30'}
2021-12-20 18:39:44.099 Status: dzVents: Info: Handling events for: "Schakelaar Keuken 2", value: "B3"
2021-12-20 18:39:44.099 Status: dzVents: Info: roomSwitcher: ------ Start internal script: DzV - Schakelaar Luik Keuken: Device: "Schakelaar Keuken 2 (ConBee2)", Index: 394
2021-12-20 18:39:44.099 Status: dzVents: Info: roomSwitcher: ------ Finished DzV - Schakelaar Luik Keuken
2021-12-20 18:39:44.099 Error: dzVents: Error: (3.1.7) roomSwitcher: An error occurred when calling event handler DzV - Schakelaar Luik Keuken
2021-12-20 18:39:44.099 Error: dzVents: Error: (3.1.7) roomSwitcher: ...Vents/generated_scripts/DzV - Schakelaar Luik Keuken.lua:27: attempt to index a nil value (global 'domoticz')
2021-12-20 18:39:46.531 ConBee2: (ConBee2) onMessage called
Not sure what that means though :oops:
Help much appreciated!
Replace domoticz.openURL by dz.openURL
keros
Post by keros »
Means that on line 27 there is a variable domoticz that does not exist. The good variable to use in your code is dz, which you defined previously (see my post above).
Sjonnie2017
Thank you both for your support. I will test and report back.
Sjonnie2017
Gentlemen,
I adjusted the code as per your instructions and I can confirm the stop function is now working.
Thank you both for your support! Truly appreciated!!
